Hey guys, had some fune tuning cars this week ....
HKS34 Made 300 kw at all four in the dyno shootout and took home 2 trophy's, and the silver 33 made 288 at all four and took home a trophy.....
Nice looking cars and thanks to their owners for letting me tweak them :D
Doc.
The HKS34 was setup by revzone, but tuned by me prior to dyno run, and yes it was peters R33 GTR that I also tuned for the dyno as well.
An intersting note on HKS34 was it made 1080 NM of torque, nearly up there with dave's 33 at 1180 NM....
They're alll maddddddd cars :)
Doc.
doc was using the dyno at the show and he has been using another dyno he will have his own dyno in 2 weeks or so. :)
should be lots of fun already talking about a dyno day but let them get it in first and yes it will be a good deal so you guys can compare your figures from good guys to doc's dyno
lots of fun to come.
btw daves r33 made 396 incase you missed it @ 1.6 br when are you doingyour upgrade inasnt?
meggala
Guest INASNT
meggala
bought 1g worth of stuff this week already, its a work in progress
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
