  • Replies 65
  MANWHORE said:
There is no such thing as a good kit period. Halogen housings have different optics to xenon housings, so they cannot focus the light properly. End of story. The only option is a retrofit of oem hid into the housing.
I'm guessing that you hvae an r34 gtt? with the xenons that have been converted from compliance?
I forgot the blokes name, but there's someone with a black r34 on here who put a kit converted headlights. The light output was crap, because the kit puts the focal point of the bulb in the wrong spot.
Go oem. r34 headlights aren't that expensive. I've seen them go for $600 for the pair in perfect nic.
hmm how do i get OEM?? I contacted my car dearler.. 1 guy said ok.. and another told me they can't do it (bastard).. it'll cost me 800 bucks and that he'll (the guy who said that it can't be done) ask his 'friend' about it..
is 600 bucks about the price for them to make it OEM R34 xenon headlights for me?
heers
i've seen halogen (4 door/non turbo) assemblies go for $600, but watching what people are finding over in the Slidewize R34 gear thread, low $900's is the lowest i've seen him quote how much a pair of xenons will cost from the yahoo auctions (delivered)
If you look at your lights evil, do you see the word 'Xenon' embossed anywhere?
I'm looking at those Xenon HID kits on eBay, sells for around $200-$600.
Thinking of getting 1 but dunno if it'll fit or not, what's the criteria?
And does any1 know the diff between xenon & bi-xenon ones?
  MANWHORE said:
110% gtst - have you read a single thing that was said in this thread? If you had, then obviously, you wouldn't buy it.
nah not really, maybe the 8000k bulb will be less blinding, anyway does the Series I & II both have H1s?
  ali-turko said:
MANWHORE, iv got an r32 gtr and i was really keen on a HID xenon kit but from what iv read they seem to be usless what do you recommend for me, my lighting at night is shit house
Same here... I've sold it by hooking up sum CAT foggies!
ali, check out Ronin's thread.
The projector's with HID kits are passable from what i've heard. Obviously not the best option.
how handy are you with building things, electrics, etc? maybe you can do a retro fit yourself.
hey ali,
The link that gohan posted up is spot on the money. It is the only 'Real' and 'proper' way of doing things.
r32 headlights are renouned for being the crappest lights ever. If you don't want to go the retrofit option, the best light you can get is probably a set of plus 50 bulbs, relayed so that they get the full 13.8 volts (instead of the 10-11 volts they usually get).
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 馃憣). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
