Howdy all,
been reading thru a ton of info about upgrading the auto in my sedan and i am tossing up over a stage 2 versus 3 kit. I know the difference and have an idea as to the pros and cons of each, but i still have a few quick questions;
If its left in 'D' with over drive still engaged (stage 3 in question), is it like a manual car trying to take off in 4th? I am assuming that the car is still going to move, but its going to overheat the daylights outta of the box right?
The stage 3 obviously allows me total control over gear changes, but if i decide to snap from 1st up to 2nd for example, how quickly is going to bump it up to the next gear?
Exactly how does the manual valve body give the driver control over when and where the gear change occurs when the auto ecu runs the changes when in drive in a normal gearbox? Am i correct in assuming that the valve body 'manually' over rides this process?
And by that i mean it alters the way the pressure of the auto fluid is moved from 'a' to 'b' thru the application of a seal or something along those lines, therefore over riding the ecu?
I realise that the above may sound a little disjointed, but i am trying to get a better understanding on the way everything works before i decide on which way to go.
Cheers,
Chris
https://www.sau.com.au/forums/topic/161802-r33-auto/
stage 2 = automatic shift kit
stage 3 = manualised autoamtic shift kit
stage 2 just hardens up the shifts but the auto does the rest still
stage 3 you have to shift for it to change gears
when i rang mike @ MV, he said he only recommends the stage 3 for engine conversions where the auto computer can't control the gearbox
if you have any Q's on how it works then call mike, he is the best person to speak to and is very happy to help explain it
https://www.sau.com.au/forums/topic/161802-r33-auto/#findComment-3004797
So i have done a run around and know about prices and bits and pieces, but has anybody got a stage 3 (full manual body) that they can share their experiences with me???
For example, how is in gear acceleration in full manual mode? Normally, u put the foot down, it has a think, kicks down a gear or two and then starts to haul. U pull it back a gear and floor it, does it react the same way?
Is general drivability affected?
Any differences in fuel economy or the way it behaves when u get up it???
Surely someone out there has some personal experiences they can share. Good or bad.
Cheers,
Chris
https://www.sau.com.au/forums/topic/161802-r33-auto/#findComment-3024579
I've got a sequential manualised-auto with a stage II shift kit. Using MV Automatic's electronic shift controller you can disable the auto ECU to make it behave similar to a manual valve body. As the name implies having a manual valve body requires it to be driven like a manual just without a clutch so, you wouldn't leave off from the lights in 4th :P
There's no O/D & kick down function so, now O/D button off=3rd & O/D on=4th...think I got that right as, I use a ratchet shifter. NB: If you have the O/D on (4th) still engaged & then shift gears the trans will flare & can shock the trans when you correct it back into gear :happy:.
With med-high loads the shifts between gears are instantaneous & crisp but, off throttle & low loads gear changes can sometimes be a bit jerky. Also, for me going down from 4th->3rd the engine brake doesn't engage & not sure if this is the same with a 4speed manual valve body. But, yes when you down shift & plant it, it will haul, as well as, chirp the wheels even in 3rd :wave:.
https://www.sau.com.au/forums/topic/161802-r33-auto/#findComment-3031364
But, yes when you down shift & plant it, it will haul, as well as, chirp the wheels even in 3rd :) .
Awesome shifter. I want the same thing. If u dont mind me asking u, how much was the elec device and stage 2 kit worth together versus a stage 3?
How did you wire up the o/d on a ratchet shifter? How difficult was it to get into place?
I imagine that your set up is the same as a full manual one, but did it affect anything like an increase in revs at certain speeds. Eg, atm 100klms is 2650ish revs. If i go full manual set up jobby, i dont think that this would change
PS - Cheers for your input dude
Edited by sxc33
https://www.sau.com.au/forums/topic/161802-r33-auto/#findComment-3032444
The B&M pro-ratchet is an excellent shifter & only downside is trying to do quick 3pt turns or if a motorkhana stage requires reversing :) :).
At the moment the O/D (4th) is wired up to the POWER switch but, plan to fit one of B&M replacement gear knobs which has a button & activate it that way.
Nah, the auto gear ratios have remained the same.
If you haven't already seen there's an ongoing group buy for the upgraded valve body from MV Autos & think Guy (4door_sleeper) has updated prices > Click to link
There's also some good info in that thread so, if you have time worth a quick read & I'll PM you approx prices for the various other items needed for the conversion. ;)
https://www.sau.com.au/forums/topic/161802-r33-auto/#findComment-3032562
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
