  • Replies 141
It costs too much for me to go to Willowbank anyway....coz my traction level is so high it actually reverse rotates the earth on it's axis which turns back time. This is how I am able to run such quick times. The only downfall is that due to my high levels of traction, I tear up the bitumen and this has to replaced at my expense. If only I could find another way...hmmm.
Hey Andy, how did the new clutch go on that last 2 you pulled...she still running sweet. You know it's an NPC rebuild so Shane might get jealous that it didn't explode, causing your car to be written off in the process.
The clutch was good....but a jim berry aluminium foil 1/3 plate with 7894723589634875637821567823135 lb of clamping preassure would have seen me into the ones
if you want...on the national giants only a sec quicker and 2 on sprint...but next time we hit the track...we should be just as quick if not quicker....but i admit giants car is a very well setup beast.
No...the dry sump is MINE! Get your own. I can show you how to fit it up good and proper.
You will love the new 26/30's soon to be built...sporting t04z and a few other bits.
And the new gearset going into the box oh and autronic.
haha i was just stirrin u up mate :D
i should look at something like that, will have to ahve a caht with you about it
swoit! that should be horn! u copied me, didnt ya!?! :(
yeh autronic seems to be the way to go :D
rofl
oh noes, i'm running 220rwkw i must need a 1200bhp twin plate!!! :P
u woulda loved bein in whoretown last nite, was quite humerous :P
haha i was just stirrin u up mate :P
rofl
oh noes, i'm running 220rwkw i must need a 1200bhp twin plate!!! :D
who cares what power its running....cheaper, better case closed :P
worse to drive, rattles like a cnut, and shtis itself after 2 months :(
NPC ftw!!! :D
Ever driven one? It is easy as, if you cant drive it you dont deserve a car. Maybe thats why you like singles??? cause yiou are a nancy and cant drive? :P
If you can hear mine rattle above the exhaust you have better hearing than me
I like my fire wall the shape it is so I will stick with what I have
Also I recall an email where you sadi you would have bought a multi if you could afford it :P
Ever driven one? It is easy as, if you cant drive it you dont deserve a car. Maybe thats why you like singles??? cause yiou are a nancy and cant drive? :D
Also I recall an email where you sadi you would have bought a multi if you could afford it :(
i like to drive calls that dont stall if ur half asleep with the clutch :P
chuck it in neutral, clutch in and i betcha can hear it! (well it should rattle then if its gonna do it lol)
proof of said email. i'm callin bs as id never say something stupid like that
shanes driven my NPC 6 puk, I didnt hear any complaints from him appart from its got a harsh engagement, its a very streetable clutch if you know how to drive it tho...
like any clutch, gotta get use to it
plus andy was talking about twins lol (which ive only driven johns, and i hated it, caus the pedal was sooo light)
i like to drive calls that dont stall if ur half asleep with the clutch :huh:
Mine is nothing like Johns, he has solid centres
And yeah you can hear mine if you listen hard and have a wall or another car next to you but I wouldnt say 'it rattles like a c*nt'
i like to drive calls that dont stall if ur half asleep with the clutch ;)
Yeah, fixed that issue. The light pedal is good for people who've never driven a twin plate before but does promote riding. This is the problem in John's case because he has ridden it soooo much. The hub's were both farked. It's the same clutch Marc has in his 9 second GTR, marc has no problems.
The clutch never failed, there was an issue with the spigot bush and an issue with the input on the gearbox. Fairly easy fixes in both cases.
The diaphragm has been changed to a heavier type so pedal should feel pretty good now.
Noels not lying either....i believe he actually fought in the first world war....kudos for defending our country mate :rofl: lol
Nah, I was too young so they made me the water boy.
p.s. You'll pay for that Michael you cheeky pup. ;)
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
