Hi all,
I recently wrote off my r33 gtst S1 so i have most parts available and some aftermarket parts also going cheap.
will be adding more parts to the list as i remember them, so if u need anything just ask.
RB25DET Whole engine and gearbox with Heavy duty clutch $3500 o.n.o
Stock R33 Brakes front and back $500 with hubs
Hicas diff and drive shaft $350
Drivers side door perfect condition $200 with recently reconditioned Power window motor.
Black stock front bar $70
Black Stock rear bar $70
Black Front right quarter panel $60 has some scratches
Boot with stock S1 spoiler $100
Rear Lights $150 for pair
Front Lights $250 for pair
Front indicators $70 for pair
front grill with the skyline S $30
side indicators $30 for pair
Air con unit $50
Air Flow Meter $100
stock bov $30
Stock Intercooler with some piping $50
set of stock R33 rims with bald tyres $200
After market parts:
Hybrid intercooler kit with red piping $250 SOLD
Turbosmart type 1 BOV $50 SOLD
Walbro 500hp fuel pump $150
Apexi AVCR boost controller with solonoid $300
Used K&N pod filter $20 SOLD
Auto guage boost $60
Autoguage Aif/fuel ratio $60
blitz duel turbo timer $40
All parts are located in Shailer Park
Pick Up prefered but will ship at buyers expence
Ph. 0423619794
Or just Pm me on here.
Prices on parts are negotiable
PICS = = = http://www.skylinesaustralia.com/forums/in...=0#entry3011250
Edited by Bizzy
https://www.sau.com.au/forums/topic/162147-r33-gtst-wreck-parts-galore/
Hi all,
Air con unit $50
Air Flow Meter $100
stock bov $30
After market parts:
Ph. 0423619794
thats some good stuff u got where do u live
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
