its a CA18det, the coolant disappears quick, idles rough, timings out and bubbles in the radiator. Are these the symtoms of head gasket or are there anything else that i could test to see if the gasket is gone.
thanks guys
Now if the coolant is dissapearing quick, check for leaks.. Run the car go for a cruise come home sit around and watch..
Now i dont know ca18's but have you change the radiator and does it have a Pressurised cap.. Alot of people notice there coolant bubbling around when they shut the car off due to the pressure from the radiator pressing down.. and also the coolant bottle having a pressured cap pressing down also..
Symptoms of a headgasket are milky coolant.
Guest 40th-edition
that sounds like classic head gasked or even cracked head 4 sure.... you can pressure test it and then leave sit with pressure over night or couple of hours then crack and see if its hard to start or even hydrolic locks..
even a TK tester would do it but i would say head 4 sure!
thanks guys
ca18 are prone to blowing headgaskets
check the lh side of the block (where the power steering pump is) check for coolant leaking down the block
but usually the blow between cylinder and water jacket so u will rarely see coolant mixed in with the oil on a ca18
btw u will get a better responce if u go to www.nissansilvia.com as there are alot of ca18 freaks on this site
the whole engine is flooded with leaks, i can't believe the last owner. since owning the car i realised the car has had a hard and neglected life :P but thanks for the advice boot_it
Welcome to the world of CA's, does there appear to be a frothy substance in the radiator only when its on? more than likely the head gasket is gone, CA's are bordering on 20 years old. The poor 4 cylinder is on its lasts legs.
Most 180's or jap cars for that matter have had a hard life, its just a matter of getting one that wasnt treated as bad as others.
Cheers, Semo
Cheers, Semo
maybe i should send it to the grave and replace it with a lil younger sr20det :D i got this car cheap, and being an automatic i assumed it was ever owned by decent poeple................... how wrong was i. :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
