All you would have to do is read the first post to find that out.
Yeah it's all Beer Barons fault that the date got changed.
How has Richard got so much pull ?? Ahh thats right, him and John have a "special" man to man relationship.
  • Replies 368
Squeaky wheel. I wanted to go to Compak attack too but I forgot it was on when I agreed to change it. Oh well, not changing it back that's for sure.
B-man, first come first on. Pay on the day.
These straight line events with bumper bars are on all the time, SAU Dyno Day is once a year. Hard to organise these things and maybe in future should do a survey of what events are on or something? Wondering why it took so long for someone to say HELLO Straight Line Event is on same day.
Dirt Garage Dyno highest dyno reading what car and with or with out NOS?
R33 GTR Top Secret Car will be here and has had more mods and should make by far the highest and make ....rwkw.
lol, sorry paul. i whinged hard. and yes it has been said i have lots of pull. or perhaps that i like a pull. i can't remember. sorry for anyone running compak attack, but for those spectating it should be easily possible to do both. UAS is just 20 mins from WSID. i definately wont be going to compak attack. i've been to one before and it was pretty bad. I hope they have pulled a finger out and put on a good event for you guys who keep supporting it.
Hahaha.. Nick & Baron I know you secretly cruise round on the streets with 22's on your gtrs.. The ones that look like garbage can lids! I know because I see you both drive up and down george street together :action-smiley-069:
Hahaha.. Nick & Baron I know you secretly cruise round on the streets with 22's on your gtrs.. The ones that look like garbage can lids! I know because I see you both drive up and down george street together :P
and eyeing up the guys in their lancers
Highest your dyno has ever gone (accurately)...easy question
Top Secret car or just a gold R33 with plates on it to decieve?? Why wont it be racing?...ahh thats right...it went racing and embarrassed itself...dyno room may be the best spot for it then.
The real test of a cars potential is the MPH on a time slip or a lap time at the track
im IN IN IN to compete. this is uni group isn't it??? cbf reading previous 5 pages. if so they are a great bunch and their dyno is known to be a lil 'happy'.
cbf ahahha tell me u dont live in teh hills area!!
close to it. wouldn't mind living in the hills area, just a pitty theres too many emos.
You love them!
I've worked it out. Emo girls go for emo guys, so they are closet lesbians because they like boy who look like girls. People need to stop reproducing these emo children.. They are infecting the world with there emo-ness.
stop saying emo.
EMO!... emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo emo.. X 11TY
I'm done.
Price check - Razor blade 6-pack
Lmfao.. Steak knifes are better.. But then they don't do it to kill themselves, they only do it for the attention.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
