Hi guys, i've been going to the nats for about 4 years now and have seen the
numbeer of turbo cars slowly increase which is great!
My car is still in the shop getting the new enging put in so mabey next year for me :happy:
So are any of you guys heading down this year? entering cars or taking in the views?
Is there an sau group meeting up?
Simon
https://www.sau.com.au/forums/topic/162387-easter-nats/
MMMMMMMMM torana's doing skids, HQ's with 350's....Nothing I've never seen before
Goto the island for the Nissan Datsun sprints on easter saturday, and pissup at the pub after :huh:
or go on the 2nd Great ocean road cruis down to apollo bay and back.
april 7th
https://www.sau.com.au/forums/topic/162387-easter-nats/#findComment-3018005
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
