after getting a defect for my car, i was searching for someone who can make air boxes. after finding somenone i asked the supplier if they would mind organizing a GB for Skylines Australia. and they were more then happy to agree.
i bought my airbox for $300 and was made out of Full Wet Carbon Fibre and is a absolute banger!!!! looks crazy, gives you a heat shield for your pod to get those extra kws and prevents defects :laugh:
his willing to drop the price to $280 delivered Australia wide if we can get 20+ people.
you have the choice of Wet or Dry Carbon Style Air Boxes.
im in the mist of getting pics so hang tight.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
this guy can mould anything you want out of Carbon Fibre so if you would like Eye Lids, Bonnets, Bootlids anythign at all out of Carbon Fibre Let us know and i can get you a discounted price
****UPDATE****
sorry boys havnt checked back in a while, YES THE SUPPLIER IS TOPSTAGE and sorry i just took pics of the product outside the car cuz im doing some headlight mods, give us a couple of hours and ill have pics of em inside the engine bay.
so if you would like to place an order please follow the following steps.
Full Name
Forum Name
PM Me Address for delivery (if required)
Car Make Year and Model
Please supply picture of pod filter bay area
Dry or Wet Carbon Finish
Edited by anDru
https://www.sau.com.au/forums/topic/162396-carbon-fibre-air-boxes/
  • Replies 45
Posted Images
Interested... Im abit concerned about the box retaining heat as im pretty sure carbon fibre has high retention of heat...
Although I know carbon is used for brakes .. so I could be wrong?
the carbon is made to withstand engine bay heat, unless youve got moultn lava in your car then it should be fine lol, the box is to prevent hot air, not hot metal or anything else. so your good to go
Do you mean prepreg when you refer to "dry" layup?
Also keen to see some pics to make a decision.
Thanks
not sure ether but he showed me a Dry Carbon which was a lil more textured then the wet carbon (gloss finish)
thats best as i can explain it, dosnt make a difference at all, just how it looks
Also very interested....How does it work does he make up a pattern of your set-up then mould a box to suit or are they more of a generic thing?
his custom made his own boxes for each model of car (32, 33, 34, Silvia range and more)
and if you got a custom setup in your bay he can mould one specificly for your car, but thats never really needed unless you got something in the way.
Edited by anDru
these from topstage?
I was just wondering that myself because Topstage only yesterday posted on NS.com they are going to have some CF airboxes for 33's & 34's up & going soon..
This product doesnt protect against defect notices in Victoria Andru.
Pod filters are legal in vic mate, as long as you dont have a FMIC as well.
And if you have one of these air boxes and a FMIC you can still be defected...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
