Hey all,
For sale are a set of R33 N1 Turbos for GTR. These are in mint condition, with a minimal amount of side to side shaft play. There is no in/out shaft play at all. When they were removed from the car they were pumped full of oil and coated with some CRC for storage....
These turbos commonly will make up to 300wkw with a good good good tune with supporting mods.
The specs:
A/R 0.42 Compressor
A/R 0.64 Turbine Housing
As far as im aware these are 360 Degree thrust bearing maybe BB? If anyone could shed some light here it would be much appreciated.
Steel wheels both front and rear
Part number:
BB 0201J
14411 - 24U10
466089 - 6C
Asking $1800
1k swap over for good condition stockies, pickup only, in melb. If not in melb price is plus post times 2.
Price outright is 1.4k plus post.
These are FIRM.
GTR stockies MUST be in good working order.
Located in Melbourne, Eastern Suburbs.
Cheers!
Mat.
0400 558 030
SOLD thanks!
https://www.sau.com.au/forums/topic/162774-r33-gtr-n1-turbos-sold/
Hey Mat,
I'm pretty interested in these and have a set (on my car) of stock R32 turbs in perfect nick, I'll also be interested in the bosch 044 you have in your sig and I'll need some 550cc injectors if you have any.
car will be in for a tune at MPC shortly so if somthing can be worked out I can whip the turbos off then
PM me a price if your keen
cheers
  • 4 weeks later...
First post edited.
^^ Note that 1k swap over for good condition stockies is pickup only, in melb. If not in melb price is plus post times 2.
^^ Price outright is 1.4k plus post.
These are FIRM.
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
