hey guys,
i bought a garret 2530 turbo the other day. my mates and i installed it properly and connected everything back up. coolant and oil lines, vacuum lines. cooler piping
when we finished and started up the car. everything seemed ok. then we went for a drive i found that i had lost power. after a few minutes of normal driving the temp gauge started climbing a bit too high so we shut it off just in case it over heated.
we then left if for the night and got my mate around who is a mechanic and he topped up the coolant while the car was running. when it was full the coolant started overflowing with little bubbles and sort of went a milky colour. and i dont really want to drive the car while it is like this.
does any one have any idea what is happening or has happened. any help would be appreciated
thanks
is it milky or brown???? and also when you disconnected and reconnected the coolant hoses did you bleed the system properly????
Hey mate,
sorry for the noobie question but how do you properly bleed the coolant system?
and what are the negative repercussions from not properly bleeding it in.
hope you can help!
cheers
Edited by R33LIN
Hey mate,
hope you can help!
cheers
at the front of the plenum on the drivers side of the motor there is a little 10mm bolt. if you undo this while the engine is running it will bleed the system. it is best to do this while the engine is cold, as it does spurt a bit of water out with the bubbles.
if you don't do it properly you can end up with air pockets, which will be hotter than the coolant. too hot= bad.
Edited by mad082
if you're bleeding a cooling system you need to have the heater on so that the coolant can flow through your heater core, and also need a funnel/anything that you can stick in the radiator where the fill point is that wont leak eg a bottle with bottom cut off taped around the threads so you can jam it in the radiator fill point. remove the 10mm bolt on plenum top up cooling system up until coolant starts to come out hole where bolt was, put bolt in about a half a turn start engine and let it idle until warm removing screw from time to time while topping up level in funnel. when top hose and bottom hose are around the same temp (bottom hose will always be colder from radiator doing its job) remove funnel put cap on and tighten bolt and keep and eye on it for next couple of days (overflow bottle level).
this should ensure there is no air in the system, if in doubt take it to a shop before you kill your motor.
cheers matt.
I reckon that if you don't even know how to bleed the coolant system, that's most likely your problem.
When you change the turbo, you get about 4-4.5 L out of that water banjo even after you've drained teh radiator.
If you just top the radiator thinking it's all full, you'll be about 4-4.5L short.
The R32's have 2 bleed points.
Its VERY important you bleed both, if your heater core is full of air that will be pushed in to the head and VERY quickly overheat the car possibly blowing a headgasket.
There is a T piece int he top heater core hose that is located behind the inlet cam cover. However, this usually only requires bleeding if you have dropped all your coolant for a flush. There's no need to turn the heater on when bleeding as the R32's constantly flow coolant through their heater cores unlike some other cars.
So... 1.25ltr coke bottle, chop the bottom off, grab some rubber hose that fits in to the radiator neck and shove the coke bottle in to that so its all sealed, fill up the system and keep the water level in the coke bottle higher than the plenum.
Crack the bleed nipple on the plenum and bleed out the air, then remove the plug on the t-piece and bleed the air from the heater core.
Start the car and bring it up to temp, again *carefully* crack the bleed nipple and bleed out the air. Then do the same for the heater core bleeder.
I have a bit of fuel hose connected to my heatercore tpiece bleeder as to make life easy.
Go for a drive and it should be all sweet.
R32's should always run at ~1/2 on the temp guage, half is ~70degree's to 109degree's.
If not check your thermostat is working correctly and failing that replace the temp sender.
The temp sender is what partially failed in mine. When it failed temps were ~1/4 on the guage.
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
