Group buy on aluminium radiators to suit skylines, trying to get organised a group buy on custom made aluminium radiators to suit r32, r33 and possibly r34's, very high quality and will be approximately 45-50mm thick and will be a direct fit without having to modify anything, if we can get enough interest the cost per radiator will be around $280-$300, anyone who is interested please contact Simon at NT Performance Turbocharging
[email protected]
https://www.sau.com.au/forums/topic/163158-aluminium-radiators/
Joined today and already posting a group buy? Sounds suspect.
Regardless, read the group buy rules before you post - A firm start and finish date must be added otherwise the thread will be closed.
Im not actually running the group buy, my mechanic who runs NT Performance asked me to post it for him, he is organising it, for all info contact Simon @ NT Performance, his details are below, the finish date is the 20/4/07, he is taking orders up until that date
[email protected]
25 Youell Street, Footscray
03 9687 3074
Thanks
Guest
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
