I run custom 3" front pipe to catco stainless barrel cat 3.5" to the resinator 4" from there to the cannon its a hks exhaust .I picked up 12rwkw when I did thisover my old 3" exhaust and that was a trial
Cheers Peter
I went from a 3.5" mild steel, to a 3" stainless and lost 4kw at top end - gained 5-6kw from 2000-6000rpm. R32GR 237rwkw. Think it depends on your power level as well as cats/mufflers/diameter.
the reason you gained mid power was because the air could syphon a bit better with the smaller piping, but at top end you had obviosly maxed out that size piping.
or it could've been due to different whether conditions, etc etc etc.
Edited by mad082
A few ppl have mentioned it but it bares repeating..the most restrictive thing in your system...is the cat, provided your system wasnt manufactured by a complete loser. I changed to a "spec R" cat ;) on a 3" mild steel system with x-force dumps and genie front and cat back. I picked up 20 HP at the wheels on my 32R. Next time I'll go a better quality hi flo cat and go bigger dia dumps and front.
They were back to back runs so that eliminates several variables, either way, power level only slightly differnt - barely noticable, but the differnce in noise was considerable.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
