i bought some angel eyes for my R33, i jus cant get the bloody headlights off! i know you have to use a heat gun or something but i dont want to melt or crack my lights :( also its kinda hard to get them in cause they are square lights!
Wow that does look great, but I agree, too much light coming off that side LED takes the focus from around the bulb where the illuminated ring is... Can this 'angel eyes' addition be linked to another led that shines down in front of the airdam where the intercooler is, like this BMW one?
Edited by Marco-R34GTT
Not questioning whether it is or not... However, WHY would it be illegal? Having that neon/led shining down the front of the airdam...
Not sure about the laws in Perth, but in QLD and NSW any neon, even inside of the car that shows while driving is illegal, i think one of the reasons was that it is a distraction to drivers. The neon in the front of the BMW is the same as having an underbody kit. Its fine for show, but illegal to drive with them on. I was told that angel eyes are illegal in all colours except white.
That is such a crock.... Anyways, thanks mate! I'll dig a little deeper and check out the WA laws...
  • 5 months later...
still not quite finished on my headlight design yet, but theres an example of my handy work
at night there not really that bright........they put off a fair bit but its more for an effect and not a purpose if ya get what i mean.....
i bought em as a complete kit from a local wholesaler in adelaide, theyre actual spot lights with an angel ring
looks mean as hell with the bumper, il post a pic........havnt got one at night though, im still in the process of getting some perspex covers made to make it look like i have proper headlights instead of 2 pairs of high powered spotties
You have a mental looking ride. I LOVE 33's more then any other series (personally). When can i see this car in real life :worship:;)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
