  • Replies 48
hey there i am looking to get a R34 gear box but it wont be for a while but i am just wonder if ya have any idea if you could fit it into a GTS-t with a RB26
a ppg gear set is no use without a box, nor is it for street driving. A gear set at that price is only the beginning, put in mainshaft, and all the other bits to make it worthy.
This box is genuinely low on klms hasnt been bashed about and is like new. Good for anyone who wants a six speed.
He did say Synchro, not dog. PPG sell both strengthened synchro and dog boxes
Does the box have limited applications? i.e due to fitment(mating to certain engines only), or is the difference internal only compared to the 32 and 33 GTR gearboxes?
There are no issues involved in mating this box up to any Rb26 as for others i wouldnt know, but would presume there wouldnt as Nissans are all rather generic.
Sorry, I am not interested in trading parts for it.
Edited by GT51R
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
