  • Replies 42
Posted Images
T'he housings are the same, but the catridge is not.
I've installed many turbos, but havne't installed the actual slide turbo because I haven't received it yet.
do the lines have enough flex to move them into place?
Are all lines out of place by the same amount - i.e. what about if you rotate the housings?
I can't answer that question in regards to the slide turbo, because I don't have one yet. So is the turbo not a striaght bolt in like it's claimed?
Although, I we did recently rotated the housings on a turbo when installign a top mount manifold. We just loosened the bolts, turned it, tightened it.
this turbo is pissing me off something stupid. if this turbo is for the rb25det hiflow is straight bolt on shouldnt it be that i dont have to rotate it to line up?
now is this going to void my warranty if i rotate it?
Edited by R33GOD
As manwhore has stated: Loosen bolts slightly, just enough to remove tension, at rear of housing. Rotate to desired angle then fasten bolts again. Same can be done for the comp/front housing.
Are you sure you are up to this? :(
If you couldn't work that out, how the hell are you going to install the turbo?
Are you modifying the oil line? From what i read there is some sort of mod required.
Do you know how to prime the turbo with oil b4 starting? Otherwise you'll burn the cartridge out and scorch the bearings. ;)
If unsure, and you think it's just; unbolt, slap in, and bolt-up then i HIGHLY advise you to take it to a mechanic.
If i was in Aaron's position, reading this post, i would have voided the warrenty already :wave:
Take it to a good mechanic; it's going to save you money in the near future!
yes i know what to do now. i have to crank the car first a couple times then start it for 10 mins. the oil lines were modified like aaron said. my dad and i are workin on it. just wasnt sure if i could rotate it.
heres my number. i wont be on the net now. gotta try n work this out
0433447630
Edited by R33GOD
warranty? it should of aligned without me doing anything
as stated above just losen the rear housing bolts slightly and rotate, make sure you give the car a good few cranks before starting it, i personally wouldn't run huge boost until the turbo has done atleast 500k's either let everything settle in, good luck with the install it is a fun job :wave:
ive installed a max over size rb25 turbo from aaron and i found the only line i had trouble with was the water line that connects closest to the strut tower..all i did was chop the metal pipe throw some water hose between it and it gave me plenty of give then..rest of lines should all line up perfect..remember dont bolt the turbo up to the exhaust manifold tight...make sure thats loose gives u more room 2 play wit wen bolting lines up...i wouldnt go rotating the centre catridge...aaron would have sent it to u how its meant to be rotated...but ur choice..
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
