hey i have some questions maybe someone could answer!
1- how do i check if i have a fuel pressure regulator?
2- how do i teel if my hicas is locked?
3- were do i get ecu chipped?
also i am putting rb25t onto my rb20det, to get close to 200rwkw should i get ecu chipped, fuel pressure regulator (if i dont already), cam gears?
also.... prices on chipped ecu, price on fuel pressure regulator , cam gears. and were to get cam gears at good price and were to get fuel pressure regulator.
cheers adrian...
Edited by rad33
https://www.sau.com.au/forums/topic/163499-some-questions-and-help/
after market fpr can be easily spotted. Sits on the end of the fuel rail usually..are u still running the std fuel pump? If so get that replaced before the FPR (which u wont need for a while yet.) Something like a Bosch 040
Hicas, just look under the rear of your car. It should have a steering rack bolted to the diff. If it does, look at the boot rubbers to see if they have been fiddled with. If they look new, it probably has brass shims under them, or look under the rear parcel shelf in the boot for a little black box wired to the hicas computer that says Tomei. Otherwise its std.
Ecu chipping..decide on how far u want to push the car in later mods. If u cant see yourself going any further get it chipped, but it will cost to remap the chip again later if u add say a larger turbo. A PFC is a good investment for full tuning the car regardless. Shaun does wonders with tuning them. Cam gears are ok, check the forums, or www.perfectrun.com.au
Edited by Bl4cK32
ok atm i have gtr fuel pump, cooler, e-boost, pod, will have rb25t on soon. then i want to go fuel pressure regulator, ecu chipped and re-mapped then up the boost... oh and bov after that! does anyone know a bov that flutters? i cant find any!!! as in like chi chi chi chi lol?
Who have you found that is able to chip & remap the RB25's ECU? In the long run it may be cheaper & as effective to get a piggyback or stand alone ECU.
:D BOV's don't make the flutter noise...I'm assuming you mean the off boost flutter noise?? that's compressor surge. You can either run no bov or put any adjustable aftermarket one & set it at the tightest valve setting.
You probably wont need to get a fpr as yet. I wouldnt trust a 2nd hand gtr pump either...
What are the future plans for the car in terms of power? I pfc is a real good investment. Speak to your tuner or shaun at least and he can put u on a good path
Dont bother with a bov, u will get defected. A pod filter if u must have a woosh sound.
i basically want to get 200-220rwkw! and maybe 12 months later get 250-300 but i really want 220!!! what do u think i should do? whats wrong with gtr fuel pumps? i now mine is very loud hahaha but yeh wat u think will get me to 200-220?
You'll need an adj. fpr for more than 190rwkwish. Depending on dyno.
Grab a nismo one from nengun or a trader on this site. Should see you through to 220-230rwkw.
GTR pumps are old.. BUt they can be good. Just throw a cheap Bosch 040 in it. More than enough. :)
I dont like GTR pumps personally because most of the time u are replacing the std pump because its old, and doesnt flow. I cant see the point of sticking a pump thats just as old on, only for a bit more flow. Id rather rely on a new 040.
At 220 u may be seeing the limits of the afm, so u might need a z32.
For those power goals (more so the future) u may need a pfc, and injectors.
yeppers.... i have a rb20det in my r31 and im gonna put a vg30ballbearing turbo on it, get a remap and run a z32 afm...
jeff from speed lab recon that should c me round 190+kws... i think from memory a remap by jeff is around the 500 mark but could be wrong..
i found my z32 afm from kansai, they were pretty helpful, also try the for sale section here and ns.com... hope that helps a little
  Cubes said:
Please don't do the vg30bb on the rb20det. Go an rb25 turbo, much more average power, spools earlier and doesn't feel as lazy with the same peak power. :)
sorry cubes no can do turbo is already in teh shops being pulled down and getting some loving...
thanks for all the help guys!! im gonna get the rb25t put on then adj fpr, z32, and bosch 040 and save for a pfc!
so were can i get cheap PFC, ADJ FPR, Z32 and BOSCH 040?
cheers
Edited by rad33
Most import wreckers should hav Z32 AFM on shelf. You might get lucky in the same respect with a PFC...........from what ive been told an RB25DET one can be used on an RB20 with a couple of wires changed around if you cant get an RB20 one. If you want an 040 new, most auto parts places sell em, second hand, shop around the forums FS sections
r 18inch rims legal for a r32? will it pass regency? also i noticed that my intercooler piping goes through the body just next to the pod filter! is this legal? regency booked for the 27th!!! 3 week wait!
cheers
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
    • House of Fatz dry dock needs a clean sadly one of the long time stables is leaving this weekend   see ya mr purple
    • Hence why I've only modified my car into a pure daily. Everything has to remain reliable & roadworthy, while providing value and grin factor. It also must not be handcrafted to the extent that the car will be immovable if something breaks because you cannot get or make a replacement to at least limp around with.
