  • Replies 133
What about this:
Ben,
Thank you for your enquiry, we can do a high flow to your turbocharger but it is a little more involved than a standard turbocharger, this is due to the fact that your turbocharger is ball bearing and has a ceramic turbine shaft. The rebuild / hi flow we carry out to these unit are as follows:-
Turbine Wheel - replaced and upgraded with a inconel(steel) wheel , either stage 1 or 2
Compressor Wheel - replaced and upgraded with T04 wheel, either stage 1 or 2
Bearing Pack - replace with an XTR ball bearing package
Turbine Housing - machine to accept either of the larger wheels
Compressor Housing - machined to accept either of the larger hi flow wheels
Wastegate Actuator - standard or upgradeable to have higher boost pressure as standard.
Costs - Stage 1 = $2250.00 Rated @ 400hp
Stage 2 = $2450.00 Rated @ 450hp, does require other mods i.e. intercooler, fuel, etc
These prices are for the turbocharger only, but remembering that in effect the turbocharger centre will be brand new and the turbocharger will bolt straight back onto the engine with all fittings.
I trust this answers you questions, please do not hesitate to email me again.
Regards
Your standard turbine housing will not let you flow enough gases to push past 200 rwkws.
Sorry better explain...
When they profile the housing to the wheel they are only opening up a small part of the housing, the actual size of the standard R33 turbo scroll is absolutely s**t house.
I dont think hi-flow is a very good option for 250rwkw...
Dremen if you are interested in going a GT30 i can FAX you a dyno plot, the reason why i cant post is coz i dont have a scanner.
true.
when they hi-flow (my understanding i could be wrong) is mill out the intake/front housing a little bit to get a better/bigger wheel into the front. They don't actually change the housings.
Don't know what they do about the exhaust. Maybe the same thing???
please correct me if i am wrong.
When they highflow they do the following:
Originally posted by DREMEN
At the moment I am running 179rwkw and thats not enough for my liking...
Gimme a call then and i'll show u what 203rwkw is... a noticable difference from 192rwkw (after i got the exhaust done down at Cobra's). Still though i personally can't even feel the difference between 192 and 203 but im holding onto the steering wheel.
I think you'd have your balls in stitches after getting in a car with 240-250rwkw. No point aiming for any higher.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
