  • Replies 57
i wish they wouldn't allow drift anywhere. It's running the surface at most tracks. Making it way to bumpy.
most tracks hey? :P
as far as i know we only have 1 proper track here (ie mallala) and a half cast track (AIR). and most of the surface is f**ked there anyway.
where are they meant to go then?
Did you have any strut braces or anything???
nope, not a damn thing. i dont care if ppl tell me it was wrong, i just wanted to give it a go. the car is fine at home atm, still in top shape after i inspected it when I got home, only thing screwed up was my rubber, melting off the rim pretty much.
Edited by Pauly33GTS-t
If Paully doesn't buy the Bilstein coilovers I am selling REdgtst you should come check them out - a bargain at $600, and they are pretty hard - perfect for drifting!
I suggest you buy them REdgtst, I need to sort out my economy by getting an ECU now so I wont be spending any money on my car on suspension and handling until i sort that out. pretty clean ones as far as I can tell and a bargain at 600 bucks. I was going to buy them tomorow but I will be doing alot of driving in my car in the next 6-8 weeks so it would be good if i could pay 68 bucks for a full tank and have it last more than 2 days.
Alternatively I have a set of Tein HR coilovers I want to be rid of. They are height adjustable, but not bound adjust. They are a very firm ride, and not suitable to what I use the '33 for. I just need some stock susp in the mean time till I can afford the bilstein group buy. Im not into drifting, but good hills runs, so the tein's must go. Red or Paully, Im after $800 + your stock suspension. PM me if you are interested :blink:
what does bound actually do, i know(think) it changes the sping compression height? is that all so that when the car hits a bump there is less or more travel in the spring
does this = a better ride if you make more travel in the spring ... hope this makes sence and isnt the ramblings of a mad man :blink:
Sorry, I should have said they are not DAMPER adjustable. Damping is in bound and rebound, thus bound was the first thing that came to my head :blink:
So the Tein HR's are height adjustable with C Spanners (which are included) which changes the spring height. Damper adjustment is internal in the shock, basically changing the valving as to how quick the oil/gas can move. the less it moves, the harder the ride, the more it moves the softer the ride. Thus the "clickable" adjustment on some shocks/coilovers.
Yes, bound (more commonly known as bump) is the compression stroke of damping. I think there has been confusion caused by some people (sponsors) selling coilovers that dont know what bound is...
$600 for those Bilsteins is a bargain, I paid $2200 for similar stuff through the group buy. Who ever buys them will not regret it...
Edited by salad
i dont belive the bound your talking about is damper
look @ the top locking nuts below the springs that is what i was trying to explain with the amount of travel the spring has
32 Step Damper Adjustable
* Precise control damp valve
* Operates smoothly on all road surfaces
* Expansion/Suppression of shock adjustment
Ride Height Adjustable
* Full length height adjustable
* Bound adjustable with separate spring locks
* High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
ISC Coilovers
That is the person/sponsor that I was talking about. He is refering to preload.
The amount of travel the spring has is pretty irrelevent to spring seat location as the bumpstops will stop travel before coil bind becomes an issue, unless the coilover is really crappily designed (spring and spring seat height).
Edited by salad
Does anyone out there know how to adjust power fc settings throught the hand controller? Every manual and document i find is in Jap.
I am also interested in getting the FC edit program to work so i can adjust settings on my laptop as the version that was emailed to me via an anonymous source last year wont seem to install. Cubes any ideas???
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
