G'day guys, i own a ca18det 180sx.
i need more ideas of how to fix this problem, basically car won't stay running without my foot on the accelerator, and when i do it won't rev pass 900.
i've changed the spark plugs, test the coils, did a compression test (all good), cleaned the most of the adaptors.....
is there anything else i should do to to get this car on the road again?
https://www.sau.com.au/forums/topic/163986-car-wont-rev-help/
not wanting to sound rude but what could be wrong with the afm? i did took the thing off and gave it a quick cleaned, and from inspection,i thought the thing doesn't have too much mechanical components nor electrical components for it to be related to any problem.
as for the intercooler, while carbie cleaning the throttle body, i did took some of the IC pipes off to clean off some of the oil, i remember i did tighting up all the clamps but will pull it apart and pull it back together again tomorrow.
uummm at this point i gonna say no to a new comp :) wallet is quiet empty now after easter.
by any chance could be related to the crank sensor?, cos i got it replace a few days before this rev problem
This happen a day after i degreaser the engine, but i did took the car out after i cleaned it, and it was fine
Edited by dOOb
Check your intake piping, I popped off a pipe today and it did exactly as you described it. Won't rev and dies if you lift the foot off the accelerator.
took all the pipes of today and put it back today nothing change so................
Is the CAS tight?
It might not be on tight enough and the timing is way out.
Check your connections on EVERYTHING electrical too. Just unplug them, and plug em back in.
........i messed around with the crank sensor, i didn't take it off just losen the bolts and turned it in both directions a lil bit at a time. NOW THE DAME THING DOESN'T EVEN KICK OVER.
CAS was tight, timing is okay after i changed the crank sensor, i've already unplugged most of the adaptors and cleaned it with carbie cleaner.
ANYBODY GOT ANYMORE IDEAS?
Edited by dOOb
try a fuel pump. i replaced one in a r33 that was doing the same thing fixed the prob
i checked the fuel pump when i changed the "O ring" on top of the fuel tank about 6 weeks ago, fuel pump looks to be near new, also checked the fuel pressure and thats okay aswell.
thanks for that tip SXC_R33, can anybody think of anything else that is causing this problem?
+1 afm is stuffed actually a really common failing part and it wuold make the car not run past about 900rpm but you should be able to start the car fine, try starting the car with it unplugged if its worse its probably ok but if its the same then it could be stuffed
its entirely possible that its the AFM as stated, and because its been running rich for so long you have simply fouled the plugs...
i'd say get a new set of plugs ($20 all up for NGK copper BCPR6ES) and get a hold of someone's AFM
change them both at the same time and see if it kicks over and runs ok
hope that helps
seeing how i've stuffed around with almost everything i can think of, next will be the AFM, will try it unplugged or swap it with a mate.
hope that helps
i've already changed the plugs when this problem first occured, but that didn't much to it but might changed to those recommended to see if theres any different.
yeah but what i'm saying is that the AFM is the cause, and the plugs are fouled because of the AFM
so a new AFM might fix the cause, but the car might not start still because the plugs are foulled
you have to fix the cause (AFM) and the effected parts (plugs) at the same time to see if this is in fact the case
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
