well I bought mine from nismo japan. can't remember exactly how much but it was nothing too bad. maybe $120 a pair. they look very good too.
if anyone really needs a set I can flog you mine and just buy some more, as my GTR isn't going anywhere for the next month and the rack bushes are just sitting in their packet.
natetune on IDA has them pretty cheap and they have comparison before/after pics of the extra lock they give.
and they come with full installation instructions. nathan was rather helpfull in answering any questiions that i had about them.
>>EXTRA STEERING LOCK TIE ROD SPACERS<<
before
after
Hi all. I finished installing my Drift Motorsport steering bushes on my 32. I do notice the difference - the car feels more consistent on sweeping bends for instance. I did have a little trouble fitting them initially as I did not think they would fit in well, but with the pressure of the stirrups pushing on them during installation everything falls in place. Instructions from Drift Motorsport are below for people's future reference. Note that fpr point 4 in the first section I had to buy a new longer bolt (M12 x 1.25) as I couldn't get the stock one any where near close enough to bite.
The two black bushes form a heart shape around the rack, on the drivers side. This shape is slightly at an angle, with the pointy end facing the front of the vehicle.
Here are some steps for installing the black bushes for the drivers side.
1) Remove top bracket and old bush
2) Lift up the rack and place bushes in line with the shape on the rack, with the pointy end facing the front of the car. Don't worry if there is a gap between the two bushes, as the gap will compress once the bracket is bolted down.
3) Place the bracket over the rack with the bushes
4) Place the smallest amount of thread required to hold the bracket in place, on the bolt facing towards the rear of the car (ie: not the bolt near the engine, the other one).
5) Use leverage and compress the bracket down so that the front bolt can grab the threads and tighten it up about 3-5 threads.
6) Tighten the bolts evenly and ensure that the bushes are aligned in their right positions.
Passengers side blue ring
1) Remove bracket and old bush
2) Clean surfaces with a rag
3) Place bush on the rack, with the split facing the rear end, where the two brackets separate
4) Tighten bracket evenly and to specification
5) If there is gap in the blue ring - don't worry as it is designed to have a gap there so that it can compress and clamp down. Factory bushes have this gap as well but it is harder to see as the bush and brackets are black.
Thanks, Ben.
  • 3 weeks later...
so if im correct, the drivers side bushes are two separate black half moon bushes,
and the passenger is a full moon with a gap so u can slide in on, with gap facing the rear of the car...
and there pretty much just clamp over...and bolted down...
correct??
and one more question..are all Nissan import cars the same?
cause i found these bushes on eBay, there pretty cheap..
but list it for 13 S14 S15 R32 R33 R34, so im guessing we all have the same rack then?
apart from the gtr's???
but i looked in the nismo catalogue ..and they should them having different p/n's and different prices too...
so yeah..
wat u guys reckon????
plus anyone heard of D-Project bushes ??is that the same as the Drift Motorsport bushes??
  • 7 months later...
Hello, the Drift Motorsport bushes are the D-Project ones that we sell on eBay as well as other forums as D-Project.
The black bushes can be a bit challenging to fit - because of the metal inlay-rubber setup. They have been designed to be compressed by the mounting strap so that the rack is locked in to place.
I will be doing a complete BLOG of our R32-R34 front 4 door RB30/26 drift car buildup over the next few months with all of the Suspension setups and products that we will be using.
You can find more information here on our D-Project ns.com thread: http://www.nissansilvia.com/forums/index.p...amp;pid=4645329
Pictures of the D-Project Bushes:
Total: $85 Delivered
We are currently working on a new CMS / Web Cart system where all installation instructions, info and so forth will be made publically available online.
Please PM your order via SAU or email.
To order simply PM us on SAU on the Drift Motorsport account.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
