  • Replies 62
Unfortunately boys and girls we have had to cancel this event due to total numbers being too low for us to risk continuing any further. Thank you very much to those of you who paid straight away.
Please send an email to admin AT renew.asn.au with your postage details so we can send you your refund, if you wish to come to Wakefield on the 1st of July we can refund you the difference just let us know that is what you want.
Damn it...... that's twice now at EC I have paid and its been cancelled.... perhaps its a sign :D ?
Email sent..... :rant:
Tell me about it Anna... It's giving me the shits.
The last one got cancelled, and the last day that DID run I ended up having a major server blow up at work so i couldnt get to the track! :wave:
The last one got cancelled, and the last day that DID run I ended up having a major server blow up at work so i couldnt go!
We could have our own EC day :rant:
Oh well guess its SAU track day at Wakefied.. although this renew one the week before sounds ok too..! Going to have a look if I can do both!
Yeah thats what I was thinking.. Wakefield twice in two weeks is a bit much for me unfortunately :rant:
MrGenius - Do you have a link for the 1st July track day? I couldnt find it on renew.
bs!
1 a week is fine by me!
DAM! I just finished filling in the registration form and had only logged on to get the payment instruction.
From reading the previous posts I was worried I was going to miss out due to it being sold out and now it’s cancelled due to lack of numbers?
When is there another track day at the Creek?
What else is on around early June?
I have new semis that need trashing!!!
*cries*
man, I was pumped >_<
cant belive not enough interest in this day - man, that sucks - dont worry Mr Genius - not your fault - its just a pity :(
well, Im going to goto driftland friday 25th may
and im buying an oil cooler
and doing an l2s day, f**k it~ :P
*cries*
Linky me up to this driftland day puhlease.. and L2S... need some practice in my boat before Wakefield!
driftland.com.au
or .com only?
one of the two!
l2s day - theres a thread here somewhere!
Anna - Im heading out soon, so see you soonish - i'll call
No worries.. il check it out... I haven't gone to lunch yet so I can come over the rd with ya :P
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
