  • Replies 43
ive checked spark, took the coil pack out and earthed it on the engine through a screw driver (the professional way hahaha)
ill test the injector and resistor tomorrow when i can, im really leaning towards one of the injectors or resistors shitting themselves....
lol @ r31, really leaning towards a shitter to drive everytime my car dies!
Rb26 would be worth more than the car lol
ill get another rb20 and run 28psi lol
slide fly down and fix it for me, ill give you steaks..... :P
Ordered new resistors so should be coming today, cant fix it today so have to leave it here another night... lucky its safe! tomorrow is D day!
the injectors and resistors came in and out 6times, due to 68ohm resistors instead of 6.8 so i dont think that i woulda done a 110% job putting them in the last time! having the shits and all......
the loud clanging, metal noise was scaring the sheet out of me last night, but i figured out that since it was running so rough it was ossicilating down the exhaust and it was shaking on the mounts PHEW!
umm. have you got your range on the mutlti meter rioght? it sounds that its out by a factor of ten.
20 resister does all 6 (2wires). not individal like a rb26. whats the compression or all the cylinders. hows the sparkplugs, so its got spark on 5 and 1? if so its an injector or plug.
well bit of modding, rewiring and checking and she runs again..
even with the weird connection injector, which i want to get rid of asap...
Dave i sent you a PM about the 1 or 2 you have laying around?
Car atleast runs now, but drives like its had the shit thrashed out of it at a drift day by some hoon!!!!
New sparkies, oil and filters tomorrow! horray
still havent washed the mud off it hahaha
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
