LTHLRB that is not the case even with me. i had to rotate front and rear housing about 4 times to get it spot on. and no i didnt bend any lines what so ever :)
*im not flaming anyone but this was the case
Edited by R33GOD
  • Replies 60
Lthlrb, that is not the point of the thread, please don't get sidetracked, I don't want to turn this into a flame war - this is about reversion, and bovs!
But, me, r33god, and CEFIE and other people I know had to rotate the housing, lines had to be bent, because they didn't line up (no my stock lines weren't bent - when I saw that it didn't line up, I took the turbo off, put the stock one on, and they lined up perfectly). The catridge was about 1-2 cm from having the oil inlet facing upwards, and the water banjo holes facing striaght sideways. My turbo was installed by my friend who is a mechanic/fabricator/fitter turner, so he's not some backyard bogan who doesn't know what he's doing.
for discussion of installation, pleae do so in nic's thread.
so do you know why the bov isn't opening at low rpm, and causing chop chop, whereas it did open with the stock turbo?
Edited by MANWHORE
cause it dosent have enough pressure to open it. i heard it will only open at 10psi and up?
correct me if im wrong please :)
on another note i had to ajust/bend my actuator forward so the wastegate stays closed when im not boosting. i fixed that today and boost comes on much earlier ;)
Edited by R33GOD
That's what I was saying to paulr33 above - that was his theory that at 3k rpm, the highflow might only have 4 psi, whereas the stock turbo may have had 7
but this is what I said - did your stock turbo ever flutter? mine never did, whether releasing at 1 psi, or 20 psi.
ur bov is prob farked. I dont really know my blow off valves.. i dont run them and dont like them...
I found with my bov connected it surges HARD like it will come onto boost. anything past 9 - 10psi it will go CHOO CHOO CHOO CHOO CHOO all the way thru the rev range untill i let go. std bov = gay
my turbo actually didnt and isnt giving me hastles (will needa c if it produces the power i was told it will produce) Fits perfectly on my new engine and i have pics to prove.
Edited by LTHLRB
Your pics don't prove anything. You can have a look at a pic of the turbo installed in my car. looks like it's standard. You can't tell that iv'e rotated the housing or that i've bent lines.
My stock bov is fine. Tested the mechanism in it, and it's the same as before.
Edited by MANWHORE
i wouldnt worry about it man it sounds good, and wont harm the turbo, well not at a lower boost level where it does flutter.
oh yea..my msn's on. sign out and back in. mines fine
Edited by R33GOD
but im too lazy to rotate a turbo around and stuff lol its not like im lying to you, im saying, that when aaron sent the turbo, i put it directly on my new engine iv built and wallah, fits fine.
You may have another case, but i dont agree that you got ripped or anything (you shouldnt have baught it if u are complaining now)
Maybe wind the boost up?
i got another point...
My mate has a 500hp hypergear external gated high mount turbo, He made a front facing plenum, there was that much pressure iin the piping and all that 6psi seized the throttle and it couldnt shut, he now runs a hks ssq bov, which on 6psi sounds like hell!
I'm not complaining! It runs like a 12 year old kid with a porno mag. Like I said to you above, I don't care about the isntall of it! that's not the purpose of this thread. I'm triyng to understadn why the bov was opening stock and isn't opening now!
Obviously you didn't have to rotate it, because you got braided lines, whcih are flexible - the reason why I had to rotate, is to give the metal lines the best chance of fitting on wiht the least bending.
I don't have a front mount. I have a sidemount. All the front mount does is amplifies the sound (echoes through the chamber)
And before anyone says omg, get a front mount before you get a turbo - I have one, I just tested with a sidemount to see if the reversion was still there with the sidemount, and it was.
Edited by MANWHORE
not everyone had the joys you did with it fitting straight on :) regardless of the mucking around we did its a fantastic turbo.
im happy ;)
Ever seen a compressor map? they're not exactly linear.. what someone was trying to say earlier is that even at 4psi and 2k rpm, the stock turbo is probably still flowing enough air to open the bov. I'm no expert, but that makes perfect sense to me.
hey ducki, are you running a pod filter? or standard airbox. If you're running the airbox, you probably won't hear anything, or it'll be very very little.
I've tried my airbox, even with a Kn panel, and I almost oculdn't hear any noise.
manwhore.
try this, disconnect the hose that goes to the bov....the one that comes from the plenum.
take it for a drive and u should have that flutter.....then plug the hose back in and see if the noise changes....if it doesnt i'd be guessing that the bov isnt working.
thats my theory for the day....
manwhore.
Yogi, the bov is working, aboive 4k rpm
Edited by MANWHORE
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
