hi guys im new to syd and i was wondering what to do i was told krispy ks on sat night in liverpool which is good cauze i live close to there.if any of you guys c me around that area come and say hi i have g/grey gtr32 with starcorp rims and vic plates
cheers josh
https://www.sau.com.au/forums/topic/164415-new-to-sydwhere-to-cruize/
cheers josh
any pics of the car mate?
