i just started on my r32 wide body skyline just want 2 know what u think of it and maby some advice
i will b flairing the front aswell but not made the flairing tool yet
i havent found any rims yet as i need an offset of 130mm as it is 3 inch wider on each side
il stick some more pics up 2mo
https://www.sau.com.au/forums/topic/164423-what-u-think-r32-wide-body/
no offence but the front bar intercooler hole is too big..looks like ur 32 jaws are dropped! And the side air ducts are too square...
thanks i l have a look at that the intercooler hole will prob stay the same but i can quite easily modify the side vents with some coving
anyway heres some pictures of the rear
is that fiberglass wide body kit????? if it is how much was it ????? lol i didint go with the wide fiber glass body as in mine oppoinion it didint looks good and the pannel beater siad that fiberglass to make it look smoother and puddy or bog as well after 12 month driveing, because of the road like bumps, shaskes and rattles it could crack so i went with GTR quarter pannels its getting wielder onto my GTST atm and i also got a front bumper like that looks awesome does it cant wait till mien is finnished i post my gtst once the pannels are on and photos of my befor and after pics which my friend took ^^....... i could of sold u my fiberglass wide body lolz had it for sale still are ^^ i got a fiberglass bonnet if you want for that car needs some work i sell it for ya for cheap :D
Hey dude, its spelt "SAID" not "SIAD", you've spelt it wrongly in 4 of your posts! :laughing-smiley-014:
is that fiberglass wide body kit????? if it is how much was it ????? lol i didint go with the wide fiber glass body as in mine oppoinion it didint looks good and the pannel beater siad that fiberglass to make it look smoother and puddy or bog as well after 12 month driveing, because of the road like bumps, shaskes and rattles it could crack so i went with GTR quarter pannels its getting wielder onto my GTST atm and i also got a front bumper like that looks awesome does it cant wait till mien is finnished i post my gtst once the pannels are on and photos of my befor and after pics which my friend took ^^....... i could of sold u my fiberglass wide body lolz had it for sale still are ^^ i got a fiberglass bonnet if you want for that car needs some work i sell it for ya for cheap :P
yea its fiberglass its home made out of timber moulds nothing was bought n i did all the work and im going to stick with that theme not 2 bad 4 an 18 year old. i have a bonnet ready and waitin 4 me 2 put some time into n get it ready. i also want 2 have a 1 off car im also going to the extent of building an rb24det as they are very rare
lol bah who cares really you understood what i mean, lol stop being a high school teacher LOLZ
yeah Rb24det, i never herd of a Rb24det must be rare lol
Edited by BRUNSKIGTST
looks interesting, the primer and sh!t makes it look piss poor. With the flared front gaurds and a different bonnet it will suit it.
Im not to sure on the front bumper the centre looks to small. Is the an FMIC there?
Ive never seen a rb20det, i thought the max i could be bored to was a to 2.3? Dont know...just drop a 25 into it.
the 24 is built with a 25 block and pistons with 2litre cons and crank
this givves the engine a very revvy nature like the 20 but the tourque of the 25
24 s only came in single cam factory and were only sold in the US so its going 2 be a complete custom build
i havent mounted the intercooler yet it just mesh at the mo
That's a pretty ambitious project you're undertaking! Good luck with it.
Here's my R32 with a widebody kit. The custom gas cap is where most of the work is at.
And you're right about the spacers. Need em big to get the wheels to sit flush.
thats awesome! one of the nicest I've seen I think...good work!
that is mint how did u du the fuel flap n are they gtr front qarters
Thanks for the comments.
There's ~2 1/2" spacers to bring out the cap. Then alot of bending to have it sit flush with the new curves of the body.
No, the front fenders aren't GTRs. The front and rears are from the same kit. (I forget the name :P it might be the same as Felixy69's) It's wider than a GTR in both front and rear!
The car always gets mistaken for one still. hehe
Edited by 604R32
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
