Hey guys/girls
I require any input that you guys/girls can offer me.
Vehicle details:
r32 gts4-t
manual
turbosmart boost controller (Boost Tee)
3inch exhaust
FMIC
stock turbo
12 psi
dump pile
2 x BOV - i. after market - ii. stock (Weird previous onwer)
I have recently converted my r32 gts40t from auto to man (this was performed at GT auto garage) with a new exedy clutch and gt-r gearbox and after a good work out..... my baby started heistating 4000 rpm so as i have read on the forums here at the SAU website it could be hair crack in the coilpacks.
SO I gluing them with arodite and performed a compression test and in the process smashed the ignitor loom plugs (where it plugs into the coilpack) so i got a second hand loom from STZ automative.
Got back home put the new loom in and what do u know misfire on idle and load. After as for a mates help (he has a r31 with a rb20det) we swapped the ignitors than tried the loom. Ignitor didn't help. Loom resulted in no misfire at idle so we jumped in and went for a spin..... on load stall. So i thought maybe sparks / coilpacks........... Got new SP coilpacks, NGK iridium spark plugs, regap.
So after inspecting the loom that i got from STZ i found that the guy had given me a rb26 loom. So i returned it. Got a second rb20det loom and changed fuel filter.
Decided to send the car to GT auto garage car didn't mis for them heistated still. I asked for a new walbro pump to be installed, plugs to be regapped, SP coils to be installed.... 50 metres down the road STALL at 40 kms..... steering heavy "battery light comes up" could it be an alternator (&%*$ dying?
Currently heistating over 5000 rpm and stalling randomly and running RIch.
Well any help would be AWESOME
I have tried:
1. New plugs
2. swapped loom, ignitor for another rb20det
3. cleaned and resolder AFM pins
4. New SP coilpacks
5. New fuel filter
6. New fuel pump
7. checked for splits in Intercooler piling
Possbility i have thought of or read from the forum:
1. plastic from the plug has fallen into a cynlinder during compression test
2. alternator is F*&ked - i will find a friend with a multi meter
3. CAS
4. ACC
5. ECU in limp mode
Help........... would be awesome or even ways to test what it could be
I might even just RIPP THE 20 out and put in a 25 or 26 when i can afford it :P
Edited by RipNGrip
Update: Haha i will reply to myself! :closedeyes:
AFM soldered and cleaned
cleaned TPS plug
checked for leaks
occasional missing on idle! Revs fairly freely and doesn't stall on release (drops to low revs)
Intermittently stall? (not completely sure - battery light comes on engine sounds like it cuts and battery light goes off) but i charged the battery (battery less than 12 months old) today and tightened some of the connections
i'm not too sure if youve done it already? aac valve. my rb20 would stall at every bloody intersection and traffic lights
that i possibly stopped at and towards the end even when i slowed down to minimal revs.
i cleaned mine and it was like a totally new car. also adjusted the idles and its a dream
also when my afm went i couldn't get any power over about 3 grand. every time i took it to mechanics it ran fine.
theyre my experiences with similar problems under any sort of load.
hopefulyy it helps somewhat.
Hey mate have u actually tried using a different afm altogether? i have the same problem as you i resoldered my afm and it only temporarily fixed the prob i tried using a diff one and problem solved.
Hope that helps
Thanks guys,
I will try and clean the AAC valve today and tomorrow and let u konw how it goes. - i think there is a DIY on this site some where just need the carby cleaner and the gasket seal.
I haven't tried a diff AFM only have one mate who has a skyline! i am a newbie to the booster club! :closedeyes:
Thanks guys
NIZ-26T - i have a K+N pod and it just been cleaned!
Cheers
Just got the carby cleaner and gasket goop so i will see how it goes.
CLEANED and no difference still misses on idle (not like a full miss more like a half miss or a short cut)
Edited by RipNGrip
BUMP
Ok update, i have done some more research on this website however i haven't had time to do much more on the car. I regapped down to .8 mm the mechanic just put them in (running boost). Starts start up..... idles fine while still in "choke" i don't know what skylines do but it revs higher and richer.... than gets warm and starts to half miss than full miss......
going to check fuel pressure and check plusitility
going to check air regulator
any thoughts anyone?
Yeh i have two BOV and i have been reading about how it can mes up idle... How do i remove and disable my atmo BOV..... i have two and the atmo sits on the intercooler piling in the corner behind the front left area of my front spoiler..
maybe remove the vaccum piling to it????
Update:
I have checked that all 6 injectors are operating. 6 = all good. Cleaned the AAC no miss on idle but it gets worse as it warms up and on any sort of load...........
thinking possible AFM or aftermarket BOV..
How do u remove/disable an aftermarket BOV that is attached to my I/C piling
Well, i got really drunk on friday so saturday was recovery. Only looked at the car for a bit on sunday. I also downloaded the r32 engine manual (it is quite helpful - answer those a few questions on how to do diagnostics). I got a multimeter and some fuel just so i could have a crack at it for a bit. It seems that the problem gets worse as the car warms up..... it even starts to miss at idle if the car is warm.
So far:
1. placed screw driver on all 6 injectors (click, click, click) come from all of them - so they are pulsing
2. cleaned the AAC valve - it was really really dirty.
3. gapped down to .8mm (iridum plugs - i am having doubts about these plugs too)
4. resoldered the AFM and performed a DIY test which involved 12v battery, fan and multimeter - .5 volts fan didn't make a difference in the voltage so i am wondering if it wasn't powerful enough a fan or my AFM is BONED. I am leaning toward a AFM currently considering it warms up and starts missing on load/on idle. if i unplug the AFM plug the car just runs rich (light black smoke coming out the back) and sorta limps.
possbles:
1. replace afm with a mates
2. clean air regulator
3. BUY more copper plugs with higher heat ranges - grrrrrrrrrr irdiums aren't CHEAP
4. send it back to the mechanic
5. POUR PETROLLLLL on the RB20DET and smoke a cig next to it
6. crank the BOOST and try and destory the car
7. REPLACE WITH RB25 or RB26 after tax time.......... :) dont'[ have that much money for half cut and conversion
Well..... HOpefull i have found the soultion and i will post it for future misfire/stalling/heistating skyline drivers later...
Ran diag mode.
Code 54 = Auto gearbox d/c > auto to man conversion :( - HD exedy
Code 12 = AFM ......... HOPEFULLY found the source of my problems
p.s addition problem which i think worked towards to stalling was a split intercooler piling!
Anyways trying to find an jap auto wrecker with a AFM and i will confirm diagnosis!
Swapped ignitor with working rb20det... no deal! It seems to spit out some small black clumps (feel slightly wet) from the exhaust and begining to think it maybe a head gasket leak which comes to life when the engine warms up! HOwever maybe i should just bring it to a mechanic which specialize in rb20 skylines!
any recommendations guys?
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
