Hi All
I have a White r32 GTR rear wing for sale it is in good condition
I'm Located in brisabne
r32 4 door tail lights the right one has some damage $80
rb20det coil packs set set of 6 however one needs to be tape up $SOLD
r33 gtst standard front rotors $50 pickup only
bendix advance brake pads full set for r32/33 $50
rb20det standard BOV $20
stainless intercooler piping kit for r32 gtst (same as the just jap kits) it is missing some of the silicon joiners $SOLD
r32 GTR rear wing $80 ono Pickup only
standard rb20 turbo $SOLD suit re-build
r33 gtst actuator $20
t-peice boost controller $15
Viscus LSD, the Viscus centred is stuffed but the rest should be fine, suit someone who wants to put a mechanical centre in $50 pick up only
if anyone wants pics let me know
Edited by Green_s13
https://www.sau.com.au/forums/topic/164733-r32-parts/
Hi All
250 Pickup only
i will get pics up tonight
Where bouts in Brisbane you located? Im interested..please email pic to [email protected]!!
https://www.sau.com.au/forums/topic/164733-r32-parts/#findComment-3053964
so the intercooler kit in ONLY missing some hose connectors... but the rest i all there.. i wil pm u if im interested in buying it... just need to check some stuff first.
https://www.sau.com.au/forums/topic/164733-r32-parts/#findComment-3086306
all the piping is there just a few hose clamps and hoses missing
illl give u 50 for the spoiler if u are desperate and can collect asap
i'm not that desperate, but if you want to come up a bit more you will have a deal
https://www.sau.com.au/forums/topic/164733-r32-parts/#findComment-3086552
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
