  • Replies 41
subsilver is the only option available to members atm, ONARUN
but there is an option to create a new one under "styles admin" I just had a look, there's about a million fields to fill out!!!!
just a note on this, the dark blue background that SDU had was shit when you are trying to have a browse at work and not get busted!! LOL
https://www.sau.com.au/forums/topic/165-arrrrrg-me-eyes/#findComment-4195
  • 1 month later...
I recommend a bit of shareware called NetCaptor. It runs as a front end for Internet Explorer and has the following work browsing features:
1) You can view multiple page in the once instance of IE and the pages appear as tabs with the IE window rather than on the task bar.
2) You can minimize it to the system tray rather than to the task bar.
With the two combined you can have twenty threads open(ing) and when you hear footsteps you minimize IE and there is no sign that you are browsing except a dot in your system tray. When the coast is clear you just double click on the dot and your twenty pages are back. It's beauty, get into it.
https://www.sau.com.au/forums/topic/165-arrrrrg-me-eyes/#findComment-4200
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
