  • Replies 61
Ditto. There was mention of it in a really old thread (in a club registration thread) but it looks like it never quite took off.
But yes, a casual cruise/meetup would be nice. Lets throw ideas around in here :) One thought is we could alternate between bris and the GC to make it easier for all, and if you don't want to go sometimes then no big deal. Would be nice to have more regular smaller events, they're easier I guess.
Thanks my bit anyway :)
Guys, the weekly meet has been tried before but unfortunately it met an early demise due to people just not turning up. However, you all appear to be keen so it may work.
Might I suggest that you make the meeting point away from the 'usual' places. This may help with the unwanted presence of others.
Sounds good so far. Well a simple weekly thread in the events area would make it simple. It can be moved each week if we wanted to, or cruise somewhere different each week but meet at the same place. All just ideas at this stage.
And yes, I wont be there every week either but it would be good when i can make it.
I think a regular time would be good, like friday arvo's. Let's not make it too official though, just keep it social. A simple thread once we get the basics sorted, and then its just who's coming. If it's simple it might just work.
That said, lets do it. Next friday for round 1?
Yes, stickers would be great but don't think that will happen before then. The more we get out and do things like this the more we will get to know each other and the cars.
Ok, before we even think of the place, what time do we wanna kick this thing off. Maybe 6 or 6.30 so people get a chance to escape from work?
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
