OK ive been talking about this in a thread in the forced induction but it seems different states have different things that are legall etc... SO
Apart from the standered BOV can you legally change it to anything else? I was told Plumb back ones are legal that true?
Please clear this up for me, what is south australias stance on them...?
https://www.sau.com.au/forums/topic/165074-bov/
  • Replies 46
When I spoke to regency Vehicle standards they said you can't run an aftermarket bov regardless if its plumb back or not, he also said I couldn't modify the return pipe or modify the afm to turbo pipe.
BUT.. ring another day and I probably would have received a different response.
https://www.sau.com.au/forums/topic/165074-bov/#findComment-3058226
so were stuck wid the standered BOV?
thanks, shame i dont live in other states lol
https://www.sau.com.au/forums/topic/165074-bov/#findComment-3058246
Looks like it.
For myself.. No bov, thin sheet metal plate blocking it off. All looks standard. 4" afm to turbo pipe.
Large afm to turbo pipe reduces the ever so slight drivability/stall issues you get with no bov.
You get better next gear boost response when not running a bov. :P
https://www.sau.com.au/forums/topic/165074-bov/#findComment-3058268
Looks like it.
doesnt having no BOV ruin ur turbo?
https://www.sau.com.au/forums/topic/165074-bov/#findComment-3058273
lol yes the bov manufactures tell you it hurts the turbo. lol
With the stock afm to turbo pipe the dose sound is fairly quietish but with a metal afm to turbo pipe it is quite a bit louder. :P
Have a read of.... Simon from Nispro.
http://autospeed.drive.com.au/cms/A_1457/article.html
Also Quiz Shaun @ Boostworx if your worried.
https://www.sau.com.au/forums/topic/165074-bov/#findComment-3058309
whats all this bulls**t about no bov ruining your turbo lol??
that flutter noise is just air getting chopped up by the blades yeah?
cubes gives good advise, however it does cause stall/drivablity issues, so larger afm is a great idea. which i need to do soon myself!
https://www.sau.com.au/forums/topic/165074-bov/#findComment-3059062
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
