Alien, no stress I think we identified the car, and i will vouch for you as I know you arrived late at Chatswood, after everyone else had left :)
The car in question was a dark blue R34 GTT and he was spoken to for driving like a twit down at the Pizza shop
https://www.sau.com.au/forums/topic/165561-pizza/page/12/#findComment-3131397
  • Replies 227
Thanx everyone for making it the success it was.. special thanx to Nick for being liaison wiff da cop chicks uleh...
and except for a couple of tools, thank you all for helping give Skyline drivers a better name.
I did my best to get her number for you big boy, but she said she isn't into latino lovin'
https://www.sau.com.au/forums/topic/165561-pizza/page/12/#findComment-3131403
Thanks for organising Marsss, was a great night for cruising. Sorry I didn't get to meet n greet everyone am relatively new to all this and felt a little out of place. All in all I did enjoy my self and looking forward to the next one.
Cheers,
Ian
https://www.sau.com.au/forums/topic/165561-pizza/page/12/#findComment-3131532
Was a great night. Nice meeting alot of you, this was the first event I could get to for once.
Sorry to D_I_F and 1 other skyline I lead back to the city... 70% of the way back was on this god forsaken road that bumped and juttered my car all the way back and gave me a hell of a headache.
https://www.sau.com.au/forums/topic/165561-pizza/page/12/#findComment-3131749
yes, it wasn't alien doing burnouts in the chatswood chase carpark. well I'm pretty sure it wasn't as he turned up late, and follwed me into the top carpark when I was doing some shopping!
https://www.sau.com.au/forums/topic/165561-pizza/page/12/#findComment-3131761
oh so u are the bloke with the mean sounding grey 32 gtr who i stalked up to that hidden away carpark lol thanks for the directions, luckily blitz and the rest of the late pack cought up to me from behind so getting to the pizza shop was a very enjoyable stressless cruise =)
https://www.sau.com.au/forums/topic/165561-pizza/page/12/#findComment-3132513
Did you have the red 33? i was in the white 33 at the end of the night when we all went home..
https://www.sau.com.au/forums/topic/165561-pizza/page/12/#findComment-3134079
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
