Hello Everyone,
Yesterday, we worked on changing the timing belt and spark plugs. Now the damn thing won't start.
I am guessing it's because of the spark plugs.
My car: 1998 R34GTT - RB25DET (NEO).
The plugs that we're previously installed in the car were NGK PFR6G-11 and we replaced them with NGK T7340T-08. Has anyone used this plug before? I am not sure if they are the right ones.
Tonight we're going to change the plugs back to the old working ones which will confirm whether the new plugs are the culprits.
My local NGK dealer reckons NGK BKR6EP-11 is the way to go. What do you guys think?
Yep. Infact, the first time around when all was connected, the car started up and after about 4 seconds, it died and wouldn't start again. We re-did the timing belt, but no luck.
We adjusted that a few times without luck. Because we had marked all angles with tiny markings before we started the work, we connected everything back the same. Still nothing.
If you havent fixed the prolbem.
Double check all plugs. Your engine will kick over but not start f u have not made sure all plugs are connected properly. Push everything together untill you hear the joins click into each other.
Trust me i did the same thing as you.
Also make sure the CAS is plugged in correctly and that you havn't bent any pins on the connecter, the pins are fragile little bastards and if theres no proper connection it wont start (it happnd to me LOL)
I reckon it was the sparks. We changed the sparks to NGK BKR6EIX-11 and after a couple adjustments to the crank angle sensor, we managed to breathe life into the beast.
Now it starts up fine and drives without hesitation, but what I've noticed with my "sharp as a dog's" ear, is a slight clicking sound. Revving the engine up, the frequency of the clicks increases and vice-versa. Any hints on this one, guys? This sound wasn't there before.
Why would it start doing that?
Belt a tooth out? jokes.
Not sure, man, is it def a "clicking" sound?? Most belts make some noise when new. My Gates one, "whirrs" a lot more since replacing (plus idle and tension pullys)
I doubt very much it was .8mm plugs that was causing issue before, would have been the playing around with the CAS that did it.
To be honest, I looked up the NGK T7340T-08 plugs and it had only been recommended for the current models of skylines in Japan. The current models are running some VQ series engine I think. I am pretty sure they were the culprits, cause with the new plugs it took one look and tweak of the CAS to get it started.
In any case, I will examine the tensioners and belts one more time just to be sure.
Last night I let the engine warm up for about 10 minutes and in that time the sound completely vanished. I drove it for a while and the sound remained inaudible (hopefully gone).
This morning I started the engine and after a couple of minutes the sound was gone again. For now then I'll put it down to the engine not having started in the previous 3 weeks.
Hopefully in the next few cold starts, it'll be completely gone.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
