I am keen to get a 2way Nismo LSD for my 4WD S1 when it arrives.
I have a few questions though,
I know how a good 2way acts in a light RWD car (My AE86), and I am quite a fan of the handling improvements it makes.
How much different will this be to a heavy 4WD car with Attesa?
Will the loss of rear end traction make the Attesa power up the front wheels?
This sounds a bit dangerous and unbalanced.
Can anyone shed some light on the situation?
Thanks
https://www.sau.com.au/forums/topic/166131-lsd-in-4wd-stagea/
the autech version came out with LSD as standard ( if it was 1.5 way or 2 way LSD I dont know )
I presume that means the 260rs Autech version? ( still pretty new to this )
so If Nissan did it from factory then it must be ok .. only thing to find out is if its a 1.5 way or a 2 way LSD
Is it going to be an Auto your putting it in?
Thanks
yeah get a manual
get a 2 way
go drifting
on a side note though
you should be fine, if it wants to kick, the atessa will pull power and put it up front anwyays
I don't really want a manual. My AE86 is setup well for sliding.
I want a practical car that can allow me to have some 'fun' when the mood is right.
I'm not worried about the rear end kicking out, more about the front end gripping up as the attesa gives it power (pulling out of the slide aggresively)
the rs4s has a lsd - in fact it has the same gtr diff as the 260rs. see http://www.skylinesaustralia.com/forums/in...563&hl=rs4s
Drive it it is hard to tell what the impact is, as we haven't really got it ever sliding! Car behaves like it's on rails...
Ian
the RS4 does NOT have an LSD
ive done standing burnouts, and well as tried to drift it, and only one wheel spins no matter how hard i clutch kick it, how much i warm up the oil my making figure 8s, no go
soooo i bought a nismo 2 way
well, considering you have a S1 RS4 NOT an RS4 S that really doesn't have much bearing here Grant. Ian is talking about the S2 RS4 S that, apart from being a factory manual, has a lot of extra gear the RS4 doesn't have, and the LSD is only a part of a long list.
Ian - is the factory lsd a 1 or 1.5? would be good to know if one ever popped up on the auctions.
i thought he meant RS4s as in plural
nope, as the post above this states - I meant a RS4S (which is what I said)! Follow the link for details.
newbie101, not sure. What does the gtr one do as it probably is the same. (As said, I just haven't had my stagea sliding at all - it doesn't do it on wet roads, wet tram tracks, or even the odd dirt road). Mind you, I'm not trying to slide it in the first place...
Ian
ive had abit of experience with the gtr lsd and in 2wd and 4wd (had around 550rwhp), 2wd = major major drift action and damn easy to control these long wheel base designs, i could fishtail up the road as far as i want and in any gear lol :) and 4wd is pretty damn good i never really tried any hard cornering with full power because i never got a chance, but 8000rpm launches and its smokin the 2 rears and 1 front wheel ;)
oh god i miss the power of my baby, the gto is seriously lacking in the power department at the moment :)
Ian
what he said.
go the RS4S !!!!!!!!!!!!!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
