Hey guys, currently in the process of putting an SAFC II into my R34 GT-T Skyline, but have run into a bit of a snag. I've found the ground wire (plain black), except a short way out of the ECU it splits, one piece of wire goes along with all the other cables coming out of the ECU (black with white dots) while the other goes up into the dash (black with brown dots) along with another unidentified cable coming from the ECU (white with brown dots).
Doesn't really seem to be enough room to attach both ground wires needed by the SAFC in the short space before the cable splits, so I'm curious if anyone can identify the purposes of the two cables it splits into, and tell me which one to splice my SAFC into?
Did a search too, but most of the info is for R32/33 and doesn't mention anything about the ground wire splitting. Also should note, the car was (to best of my knowledge) 100% stock when I purchased it, so I really doubt that this is some aftermarket gizmo someone's wired into it...
Many thanks!
https://www.sau.com.au/forums/topic/166289-r34-gtt-safc-ground-wire/
maybe its for a turbo timer or something?
running the ground wire for the safc down to the ecu and coming back up to the cd player area is too far. why would you do it, let alone bother. apexi manual says not to chassis ground it anyway
That ground wire is for the safc's afm signal ground and they are very specific in the installation manual about the place it needs to be grounded (to the ECU). Personally, I wouldn't just earth it to just anywhere on the chassis without speaking to someone who has a strong electronic background and can shed more light as to whether or not the quality of the signal will suffer if earthed in this way.
Yeah, Apexi say grounding it to the chassis is a huge no-no, I think Eug must be right and the 2nd cable is my turbo timer (its about the only thing in the car I haven't done myself, and as such I'd forgotten about it). So we grounded it to the other one, the black one that goes with the rest of the loom, and its perfect, how simple :(
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
