  • Replies 90
  • 4 weeks later...
  • 1 month later...
Hey Brendon - don't wanna hijack your thread with my woes.
Actually not that bad - just a minor leaky headgasket late last year, but gave me an "excuse" to drop out the motor and strip it down. One thing has led to another and now have.......new head, oversize valves, drag head gasket, smaller -5 terbs, smaller IC, Tomei manifolds, smaller Nismo plenum.
Am now a full on "response adict" lol. Gunna cost me top end (and prolly prevent me cracking the elusive 10s 1/4), but should give me a serious amount of mid range torque.
Trying to get everything back together for MV - maybe possible but will only have a "skid tune" at best lol
Looking forward to a big season of sprints, track and Targa events :P
Managed to pick up 'Best Engineered & Underbody' in the 'Late Model Performance' category at Motorvation #22 at the weekend. Considering this car show'ss mainly oriented to more Street Machines, Hot Rods and Muscle Cars, I was pretty happy that an import picked this one up.
http://www.sillbeer.com/
Cheers
Brendan
Well thats cool, as I have a lot of parts off my S13 on the GTR. THough the GTR is in need of some attention now and since I ahve moved all my tools are in storage, it is time to let the baby out to a workshop me thinks, just need to find some one I trust now that I am living in Perth. It would also help if I could get my Aprilia back so I would have some wheels.
  • 2 months later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
