Hi guys,
So I got a WRC to clear my canary... will be bring it to Vicroads very soon to clear my defect... now... an EPA notice arrives asking for me to bring the car into the EPA testing centre to get my exhaust tested etc...
So now the question is... if I got my canary lifted etc... does this mean that I am legally allowed (as far as VICROADS is concerned) to drive and then will have to past the EPA test for my exhaust as a separate matter? Or do I have to pass both and get both lifted / resolved etc to start driving legally again??
some quick responses will be good as I will be getting the canary taken off soon - thought if both has to be done, might as well hold off a bit then get both done at the same time to save some time / money now...
Cheers,
https://www.sau.com.au/forums/topic/166340-canary-vs-epa-are-they-independent/
While im here, you do know about the $1100/3 demrits incoming for P-Platers dont you?
Because by the sound of it, you might aswell sell up now before it costs you :(
WTF??
does it only affect p-platers that get their license after the july date not vetrans like me?? or does it?
Thats very wrong. You should read the whole website as you dont understand the current laws, and they are the ones im talking about.
Seems you and google need to become acquainted :(
Here is one of the many threads from the past 6 months on this topic.
Responses are the same, and it seems a lot of people dont understand the law, even when its clearly written.
It affects current p-plates as currently its an offence
http://www.skylinesaustralia.com/forums/in...howtopic=166159
If you are on your P's before July 1st, your allowed to drive some cars such as 32's legally but because 33's are over the 125kw/tonne limit the fine has increased to $1100 and 3 demerit points.
EVILTD if youve got any more than a month or so left on your P's (if you still are) id sell up if i were you...
I got like 1 year left on my P's...
By the way... a NEWSFLASH... just went to the local police station and asked a senior constable... his answers were... if you get your license after July then no turbos, V6/V8 etc... but... before that then you can still... however there's a new law coming out soon... STOCK AS A ROCK is what the Road & Traffic Authorities want sports cars to be... arrive alive they say,... I guess... so for all you modders out there... RICE / PERFORMANCE mods will die unfortunately soon.....
Dicks to that idea
ak - wrong
Please for the love of the forum stop posting crap.
Sort of. Under the new laws; P Platers aren't allowed to drive cars where "modifications to a car in order to increase it's performance" are present, as well as nominated high performance 4's, 6's, 8s, Charged, and also cars above Power To weight.
It is so clear and has been said so many times.
If you dont get your licence before july 1 2007, get a corolla or something (and a track/drift/drag car on the side (and a trailer)) :blink: until you get off your P's.
Alternatively, move to a good state.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
