Umm, blowing blue smoke doesnt mean your car needs a service. It means that oil is getting into the combustion chamber. Could be caused from genral wear and tear, Flogging your motor while its still cold, Improper tuning. Does the motor backfire at all?
Dont wont to point the finger at anyone, but it sounds a little sus about how many Ks the car has considering its a 92 model. I would say that the clock (EDOmeter reading) has been turned back a few thousand ks.
Take the car back, thats BS. Dodgey little car yard pricks
its not 17,000km guys!!!
170000 la=.=
170,000km can't u read..
if its blue smoke yes, a sign the compression is going. if its black smoke, then its just running too rich.. just needs tuning.. and well the oil is ink-black.. it needs changing.. i've offered to do it, she don't want me touching it so what do i do..
Dude, thats fine even at 170,000 that means that the car on average has only done about 15K each year! to date. Compared to the average of about 20-25K P/Y. it wouldnt suprise me if this car is more closer to the 210-220K mark.
predator,
She said its blue smoke, and yes your right it sounds like the motors copmression is up shit creek. So what does that tell you? the motor is older than it is, or has had a really hard life.
If you bought it with a warranty then don't service it now at your own expense.
Ring them & tell them what's happened & that you'll bring it in after your exams.
Meanwhile, concentrate on school & get that out of the way.
Good luck (& don't trust dodgy car yards, no matter how "nice" the salesman seems).
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
