Supporting mod selection such as cams, manifolds turbo, exhaust etc will be the key to putting the power where I want it. ( and that isnt where you have it) Time will tell if i am right or not.
Question tho;
Where do you want the power???
Where do you think my power is???
  • Replies 185
Posted Images
Strike! Knew i would get a bite Col. :P Wait till I get my tune. I want to work with the tuner on the power curve.
I do no not want a light switch. Even though the hp will be up there I still want to have it come on in a linear fashion albeit at a higher plane than I originally intended. Projected power is going to be in the 350/400 rwkw range so we will have plenty to play with with regards to where we put the torque curve. Its going to be very interesting indeed.
my rb25 made 490rwhp with HEAPS more to go, and full boost by 3800rpm... I reckon you'll be on the ball pending turbo
Turbo is definitely where its at along with cam selection Josh. I still havnt made a final decision on it yet. No hurry tho. I have to amass some more funds now. What are old gigilos worth these days. :P
Yeah, half the battle is in the boost controller Noel
I have have it like a light switch or I can have it gradual...
At the end of the day it does not make more or less power, it just makes it more streetable around town and more comfortable to drive...
Will be interesting to see who hits a 10 second first :P
I think they are somwhere around -$5 per hour
The slapped out whore's around here charge out @ $132 for the first hour, then a discounted rate for the next. I reckon we put you in a suit, and BAM. We have our selves a $100+ man :laughing-smiley-014:
I will
You're assuming that I can last an hour Josh!. :laughing-smiley-014:
The battle to the 10 second quart is it, I say you'll need more flow :P i recon turbo choice change noel The GT 35R or T04Z bah meh im out catchya all tommmmmmmmoooorrow
I did a 10.8 on two HKS GT25/30's, flow my ass.. they are baby turbo's!
It's more about the overall package to be honest
A GT 30 got col to 131mph looking at some times here of other R33s tells me that if Col can get a 1.7 sec 60 footer he should be able to run a 10.8
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
