I agree about cutting off the tabs. I do that too.
You can use hose clamps mate. I have 2 hose clamps on the pump in my car.
I'm pretty sure that the wire on the side of the pump isn't for dual stage. It is just a ground. The reason I know this, is 32,33 and 34 pumps all have that extra side ground.
I didn't install the side ground for my car, and I do get the 2 stage. On idle, it's soft. If I blip the throttle, it goes louder.
Cheers
Chris
  • Replies 75
hey guys
with installing a gtr pump, are they a direct swap for the gtst? i got a 33gtst and wanna put a 33gtr pump in that i have lyin aroung. will this work? ill be shooting for 220rwkw?
cheers
danie
l
Edited by cheez
Well Ive been having issues.
The gtr pump is a bit of a fiddle to get into the GTST.
You have to be careful with how your rotate the body of the pump. The GTR pump has a piece at the top (not sure what it is) Maybe a relief valve or something.
This fouls on the tank if rotated incorrectly.
See fouling on pic..pump couldn't go all the way down
Also when you take the sock off the GTST pump you cant use the post and lock washer as you need to rotate it to the same orientation.
Chris did you find the same problem? When you push it on hard it seems to hold pretty tight. Hopefully this is ok.
OLD PUMP
I still haven't been able to test it as I need a new tank seal as mine is rooted.
So for me it wasn't a 2 hour job :D
NEW/2nd hand GTR PUMP
Edited by benl1981
Mine was different again. the R34GTR pump is fatter, cased in Rubber and is Black in color. Im also having issues, As also I cannot get it all the way down. AS the pumps casing has also its own Hose clamp on it. which is in a position that it fouls the side of the tank also, and I cannot just turn the clamp around as the clamp has 2 teeth on the far side of the clamp which earths to the middle of the pump. Wondering if i should just remove the pumps casing clamp altogether, but this earth will no longer attach..
Mine didnt have that Weird thing on top of the pump near the Terminals like yours does ben.
Edited by silverbulletR33
hang on ben. I'm a bit confused. did you cut the bottom of your bracket off?
When I installed my gtr pump, you know that metal pipe up the top? I had to cut that up (so I used to next nipple to clamp the hose). The pump was significantly taller.
that way, I could still have the pump sitting on rubber, sitting on that bottom part of the bracket. That's why I was asking if you had cut the bottom off yours
Edited by MANWHORE
Yeah I cut the bottom of the bracket off.
When you rotate the body of the pump so that the sock will angle the correct way the bit at the top fouls on the tank. SO I rotated the pump so it doesnt foul but then I can't use the locating post for the sock.
Was wondering how you did yours.
I cut some of the pipe you are talking about also.. so that it sat on the next bead..
Edited by benl1981
Well I got it all the way down now. My +ve terminal is next to the bracket I think. When you swapped over the sock it would be the wrong orientation if you used the locating post..did you just push it on as tight as possible and not use the locating post and locking star washer?
Edited by benl1981
I have mine attached still using the bottom part of the bracket. For me, cutting the top pipe was enough. I have the sock clipped on.
I did it when the tank was full, so couldn't see how far down it went, but it felt the same as when i had taken it out.
Are you sure it's not all the way down? is that how it was when you took it out? if it's fouling, give the bracket a bit of a bend.
Well I guess that makes sense then. Do you have problems with when you get really low on fuel i.e. it not picking up the last 5-10 litres?
Oh, you didn't use the post either is that what you mean?
I don't see it as a major problem but thought maybe I hadn't lined something up right.
Edited by benl1981
Haha, ok, what i did, is you could say the sock faces the wrong way. i did use the clip. Basically, the sock still points down, just slightly backwards. When I stuck it down into the tank, it still sticks down to the lower part of the tank anyways. No problem with low fuel (having said that, I normally fill up at about a quarter tank - I don't go down to the empty light. but even the empty line is fine on my car).
If you want the sock the right way, and use the clip, you could just bend the bracket out slightly, or space the pump out a bit with some efi hose. From the looks of your thing, even a couple mm would help it clear. But I don't think it'll come off even without the clip.
I can't believe that you cut the bottom of your backet off. There's enough room after you just trim the top barb back a bit. lol. I like that part, because from a mechanical point of view, imo, it would stop the pump sliding down. If I was you, I'd add another hose clamp on (yes I know it's clamped to the hose above). Like I said, I like things perfect, and i am anal.
Well if you leave the bottom piece for the pump to still sit on it it has to be spaced out from the main assembly that I was hose clamping it to. So I just chopped the bugger off.
1 hose clamp will do..as you say the hoses are holding it and the clamp. There is no real load on it. Maybe some vibration from the unit but 2 is overkill. 1 in the middle of the 2 ridges on the pump is good for me...
My tank seal was a bit split and when I tried to put it back in its become all mangled. The petrol has deteriorated it and made it all tacky etc. the car is almost 14 years old now!! And I'm going to be pushing it to make as much power or more than a new 6L v8 hahah
Edited by benl1981
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
