Well guys im finally looking at getting my car back on the road.....
Its been sitting in my shed literally unused and unrun for just over 2 years now. The reason behind this is i took a traineeship and blah blah so i could get ahead in life cash wise, well i am ahead now and im gonna get this baby back....
What i wanna know is considering it hasn't been run or used for SO long (surprisingly all the tyres aint flat!) what will i need to check over before taking her out on the road safely as i dont particularly want to be a danger to myself, my car and especially others.
Now im assuming, timing belt, oil, g/box oil, water pump (maybe?), front and rear diff, fuel hose?, fuel lines, brakes?
If there is anything please let me know, thanks guys!
Also by the way the car is a 93 R32 GTS4
Cheers
Maybe change the belts.because they are rubber and they have been still for so long.
Look for cracks,rips/tears general signs of wear.If they are not nearing 80K done on them,if they were not exposed to rain and the elements id say the belts will be k.Look at them give them a wiggle and see if they crack or not.
Dont worry about the water pump straight away.it might still be allright.But if it leaks you know it's time to change it.
Any1 feel free to proove me wrong.
You shouldnt have left the car,and not turned it over at least once a month for a warm up.
Mine was off the road for 1.5yrs.But turned over once or twice a month.the same belts,bar the timing belt,were left on and they had been going strong up untill last week.
So i did the oil and filter,brake fluid,timing belt,diff and gearbox oil,new radiator water.Water pump(tho it did need changing) urs may not.
PS:start the car up on a flat surface seen as tho it has sat for so long the oil will most surely be at one end of the motor.
nothing, just fire it up and drive. No different to my car that was sitting in the garage for half a year doing the turbo.
when your car came over from japan, it coudl have been sitting in a holding yard for months. The wharfies would have prepared your car for driving by cold starting it and ripping a burnout at the rev limiter off the boat.
Edited by MANWHORE
I love this guy's responses.
If your paranoid when remove the plugs, disconnect the cable that goes to the crank angle sensor, and crank the motor till you see oil pressure, refit plugs and cas wire, and away you go. Best to do this as there would be no oil anywhere.
Agreed, but i would first change all fluids. It's easy to do for peace of mind.
best to listen to these guys mate, you will have 0 oil pressure as the oil would have come off the bearings of your motor as well as your turbos. i wouldnt turn the car on unless the gauge started reading oil pressure from cranking it (pulling CAS out and turning key).
dont listen to this guy. just because someone MAY have treated your car like shit, doesnt mean you need to.
don't listen to this guy...
Don't listen to any of em man :blink:
Procedure:
Wait 20min after a meal ( just like mum said b4 swimming), Replace oil, check brake / slave cylinder oil, tyres belts for cracks, coolant, disconnect CAS, crank till pressure, reconnect CAS. While its idling for 2 -3 mins while revving gently, smack yourself in the face for not driving it in so long, check you got your granny nappy on, beep the horn to arouse the stoned hippy off your bonnet and call 000, realing off that theres an "officer down" 40clicks east of your favorite stretch of road ... its Skyline Time!!!!!
joe, i was being slightly sarcastic about the wharfies. My message wasn't totally sarcastic though.
What I was getting at, is people often go team extreme just because of the fact that a car has been sitting there for a little while.
Fuel - will go off, so i'd drive easily until i can refill again.
oil - oil guru websites have generally said that there is no difference between oil sitting in your sump and in a bottle. If it was new before you left it, then it's still new.
filter - why would it go off
coolant - needs to be changed every 2 years anyways.
diff and gbox oil - refer to oil above. I'd like to further add, that gearbox and diff oil needs to be changed even less frequently than engine oil, so it's even less of a concern than the engine oil.
pas fluid - same.
belts - should be fine.
I do agree with disconnecting the cas and giving it a crank though - get some oil flowing before you start it.
I also agree with starting it and letting it warm up - should always do that anyways
Edited by MANWHORE
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
