Mines Tuned Factory Ecu
Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes. -
The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again. -
@silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points? Please don't do that. Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check? -
On the V36 you swap out the whole unit and get a large vertical screen, a unit that just does the screen at the top, or you can swap out and get a replacement Aus unit to replace the Jap one (no car play/andriod auto) still keeping the Jap buttons. The cameras can be upgraded to one rear HD cam but you loss all others. Its a dumb system that puts all feeds into one input for video, and these upgraded units only seem to have one video input in them too.
