for the 10K is is going to cost to do the swap your sr with another 10k spent on it would eat the 26. a stock rb26 in a S13 is a slug.... trust me ive been there.
Wow, you must drive 8-9 sec cars on a daily basis if a stock '26 in a s13, let alone a s14, is a slug
Car:
1995 240sx SE
RB26DETT, stock, no power mods, running 14ish psi
Slicks
LSD
Stock suspension
Times:
R/T..................0.277
60'..................1.752
330.................5.027
1/8..................7.679
MPH.................93.52
1000...............9.956
1/4..................11.863
MPH.................120.64
Feel free to check out the discussion of this post @ http://forums.nicoclub.com/zerothread?id=145454
btw: i use his car as an example because not many people put a '26 ina 240sx and leave stock turbos on. one of those "might as well before it goes in" kinda things.
Edited by klh6686
i was just down the road looking at a running gtr motor in a car(shit heap) with a box (25det) behind it
drove up the street no dramas
shit the clutch didnt even slip
4k take the whole thing????????????????#
now assuming it has compression
i dont see how its going to cost me another 2k to buy a r32 crossmember and a r32 radiator, shit for 6k i can even buy the compression tester, the engine crane and a few slabs to get us through the 8 wires we need to hook up to get the old girl running. even enough in the budget for oil and filters
#note: i do realise that the engine probably is not the best one but hey it can be done
#this would be a cheap job and you would be up for extra cash eventually... or you might get lucky!
anyway beer rocks!!!!!!!!!!!!!!!!!
Slicks
Need we go into it more?
Put slicks on it with the SR with cost vs cost mods and you'll see the same, if not a faster time because money saved on the conversion goes into SR powerups.
