Hey all,
I have an R33 GTST. I have GCG hiflow turbo with all supporting mods. Z32 AFM, injectors fuel pump PFC EBC etc.
I have taken it to my tuner and the car will ping in the higher revs
The first time he said it was bad batch of fuel (BP ultimate).. so i took it back with a differnt batch. The car was stil pinging. He was adamant that it is bad fuel. (Car made about 220rwkw) To prove it was bad fuel he put in Octane booster and the car jumped up to 240rwkw with a bit of tweaking. He then pulled it back to about 220rwkw just so i wouldn't have to use octane booster all the time.
Now over some months i tried different fuel Vpower, vpower racing. etc. Would always ping up top on high boost. ( i back off straight away when the engine light flashes). I decided to check my AFM and found it was covered in oil. I bought the AFM second hand and didn't check or clean it before putting it in. the previous guy must have been using oil based filter or something.. a quick clean and the car is running much smoother but still pinging.. Also i got a metal intake pipe installed, which made the car feel stronger. But it would still ping on some occasions usually the first time i give it a hit, then after that it wouldn't ping anymore.
Now i took it back to my tuner and without touching the tune, the car made 240rwkw but it was still pinging the second run made 220rwkw with no ping which my tuner said that the PFC is self correcting it and pulling it back to protect the engine.
Again he says bad fuel. The car has now been put back to 220rwk with no ping highest knock is 15 to protect the engine. But the car just feels lifeless.. it's not even fun to drive anymore.
Now what is causing the ping? my tuner says its fuel but i just can't see how i've been getting bad fuel all this time.
Could it be my cat? its a hiflow catco one 3" but the body isn't much bigger than the ends.. should i try metalcat or something. I have a 3" bellmouth front/dump pipe, should i go for split dump?
My tuner says to get more power i will need cams. But i just think the car should be making more power if i can just find out why it's pinging. it's just boring to drive now. before i took it back to him the car pulled hard, but since the detune it's just crap.
Now i really like my tuner, he's done alot for me, but do you think i should take it to someone else? it feels like i'm stabbing him in the back if i do.. haha. The reason i'm posting this is hopefully someone will have some ideas on why it's pinging as my tuner is out of ideas.
Please help!!!!
https://www.sau.com.au/forums/topic/167590-pinging-dilema-need-advice/
  • Replies 50
i had similar problems with my rb20, i thought it was fuel, and tried all types, even used ocatane boost, still was pinging
at top end. i was told to adjust the timing, so i adjusted the crank sensor(i think thats wat its called) and moved it a few degrees to the left.
pinging stopped...
im sorry, a bad batch of fuel happens once in a blue moon.. not every time you fill up.. no direspect to your tuner, but if hes saying its bad fuel every time, then maybe its worth taking it elsewhere for a touchup tune. retarding the timing a few degrees can help, but your removing power and changing the tune.. i wouldnt be doing this without having it on a dyno to see the impact its having.
take it somewhere else to get a touch up. if they cant make it work, at least you know your tuner isn't full of hot air. then you can start considering other possible reasons.
I was gonna say the same thing, sounds fishy... Bad tradesman blames his tools...
after this comment alone, get another tuner.
The car went from 240rwkw then to 220rwkw and for the tuner to just blow you off by saying "The powerfc is taking timing out" is crap.
Powerfc's don't do this.
I don't think your tuner knows what he is doing..
New Tuner!
Under normal operation the knock level is really low maybe 5 -12. But when it's knocking it can be between 80-95.
I don't have excess oil in my pipes. Just the AFM had oil on it from the previous owner.
Before he detuned it, the first run on the dyno hit 240rwkw but it would be pinging. Then do a second run straight after (no tuning) and it would hit 220 no pinging you can see the graph is slightly lower all the way through the rev range.
Weird!!
If you turn the car off and do it again the same thing would happen.
Thanks mafia.
Yeah it appears instead of just adjusting it up top when it is pinging he just retarded the whole thing so now the whole curve is just crap. Not too fussed about peak power, but the lowe end and midrange has been dropped as well which makes it not very fun to drive.
I also have the same problem, my tuner said to get the injectors cleaned and check the cat. I also have a adjustable ex cam gear (came with car). and its about 4deg retard. He said that it doesnt need an adjustable cam gear on stock cams and said to set it on zero. But i read here somewhere that it gives a few KW??
Edited by chunkylover
oh k i c...it just seems like sumthing that hitman may say..lol..no but srsly, if it is bothering u so much (and i know it would me too) take it somehwere else. at what rpm does it start to detonate and through which gears. btw why did u detune it?
Well on the road it pinged in first, but then i would back off straight away. It would ping in 2nd as well if i hammer it from 2nd gear. Pink around 5K -6K RPM. Dyno was in 4th gear and it pinged then.
So frustrating. he detuned it to stop it from pinging. but it has affected the whole rev range
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
