hi guys... now i've had my car badge removed and this black shit has been left there and its hardened what can i use to get that crap off?
i have onli tried hot water lol and some kinda oil shit but im really scared in damaging the paint
also there is laquer of glue there from the badge too that i cant get out
anything that would remove these?
Edited by Zas)-(
https://www.sau.com.au/forums/topic/167645-glue-or-black-sealant/
i dunno what goo thing is is it sumfin to remove glue?
i do have metho but wont that cut the paint?
shit !!!!! hairdryer...no hairdryer i just chucked it in the bin... 2 weeks go
hot water?? more hot water and metho?
I wouldn't use metho mate, you can damage the paint over time doing that, happened to me after some annoying little s**t spray painted the back of my car with obscenities :D
Maybe just apply heat as suggested and perhaps that big kevs goo remover os something similar?
Eucalyptus oil
You can get it at the chemist and it won't affect the paint. Brilliant for removing just about anything sticky. Saturate some cotton wool and keep wiping. Turn the cotton wool every time it gets gummed up and use a new cotton ball if necessary.
By the time your finished you should have cleared your sinuses as well, hey presto, no more cold :D
Eucalyptus oil
yeah i used eucalyptus oil.. it aint coming off its as if its become laquered on.. nah methylated spirit didnt take it off maybe cause i onli dabbed abit onit but i will try the wd40 and the eucalpytus again
cheers guys
btw the glue has hardened.. are u sure it will soften up and come out?
it is no longer sticky everything is like rock hard sh*t....
lol
bit turps never goes astray
Yeh man I used turps on mine and wrecked the duco, my mistake was I was at work and someone had sprayed C**T in huge bright orange letters on the boot of my car, so like an idiot I wiped it off using too much turps and didn't really wash it off all that well... So I had to respray the whole boot :D MAKE SURE you wash it off well if you use turps!!!
mineral spirits will remove any glue residue/oil residue on paint.
Paint has been treated to withstand mineral spirits so there is no risk in using it.
mineral will remove oils off paint, including wax (if you applied any), so best to re-apply wax in the area which was covered in spirits.
Mineral spirits are a low cost version of body shop prep chemicals like Prepsol or Acrysol. They remove wax and other chemicals from the paint surface.
All are safe for cured automotive paint finishes.
*Source Mothers Detail product support forum
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
