  • Replies 240
Excelent :D
Keep the payments coming please, you have limited time left to book your spot...
Numbers will be made up with other car clubs if we cant get enough spots paid by the 8th of June...
This event will go ahead rail, hail or shine so get your payments in asap please...
But I'll still turn up in the GTR!
Cool, at least your coming with one car Cam, will be good to see you again back in a skyline...
payment made iam in!
WOW, that was quick, thanks!!!
Karen (SMR33) will confirm your payment shortlly...
Ill be there to watch, Pending i can get a lift!
This looks awsome will be good to meet some sau guys.
Please do its events like this that bring the forum together to chew the fat over a bbq lunch...
Excelent :P
I'll definatly come if i can con someone into comming as well, If not anyone willing to let me slart with them let me know :D
I get my licence in august so i cant wait to come out to some qld sau events.
Edited by OBNXSH
Both Karens post and the very first post show who has and has not paid yet.
Im a believer in "Build it and they will come"
Payments will flood in this week, its always the way people leave their payments till the last minute (not sure why).
But they do, and Ive spoken to Mark about it and Ill see what he has to say but at this stage we are still 100% on for a dyno day.
Get your payments in NOW then pm SMR33 to say you have done so, Please with sugar on top.
ill bring the ceffy out for this, also Series 5 might bring his rotor out if thats cool?
sorry col, the ceffy on has 180klms of its run in done and its not gonna be ready in time to run at this event.
ok thanks, but still come along it will be fun none the less...
I have spoken to Mark and he has lined up a further 5 high HP cars to run so this is a definate event...
We are 100% for go and will be running reguardless... So get your payments in now if you were wondering if we would cancel, you need not fear its ON!!!
Thanks Karen for you help :D
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
