i'm guessing not too much, the rear hubs shud bolt in all gud, you shud get a31/s13 cntrl arms pressed into the front hubs,
the only thing dat i'm not too sure on is if the a31 rear half shafts fit in the hubs
i no theres been at least 1 cefiro wit r33 hubs, but i've seen at least 2 cefiro drivers sell their 5 stud conversion kit from a r33
GL :blink:
R33 stuff will work in the rear, well, just use the hubs, the discs and calipers will be different. with the front, you can use the calipers and rotors, but the rest will have to be S14/15
how do the rear dics and calipers differ ? apart from being bigger, vented, twin piston etc? different hand brake setup?
so the front hubs dont fit at all?
thanks for the replys :rant:
You should be able to fit the R33 rear brake set up. I beleive they use a drum set up handbrake with the same drum diameter as the Cefiro one. Im unsure as to whether the S14/S15 rear brakes can be used as I dont know what handbrake set up they use. You can bolt up the twin piston calipers off the R33 if you use the corresponding discs.
I have what I believe to be R33 rear hubs, but they wont bolt directly to the Cefiro. They have an extra lug on the backing plate which would need to be ground down in order to mount them.
As for whether they have the same number of splines as the Cefiro half shafts, I am yet to find out.
Cash
ive tried rear R32 Disks and the diameter of the disk is bigger than the cefiros, so it wont fit. i just redrilled my stock cefiro disks, problem solved. the only way i can see to use full R33 rear end is changing hubs/disks/brakes and the part that everything bolts too (stubs?)
thats what i have said i am planing on doing ....im using everything
i said are r33gtst 5 stud hubs AND brakes a bolt on
Edited by Resin
  • 3 months later...
ok just confirming so others know that THIS WORKS
i used s14 front hubs and LCAS (although i want to change the S14 LCAS back to A31 = i will get to this later).
Front r33 calipers and r33 discs. NEW brakelines as i didint like the idea of cutting the bajo bolt.
Rear
Everything was R33 HUbs, calipers and discs. and drum brake. Not sure what Cash31 was getting on about ...there is no extra lug that need chopping off.
THe rear hubs & drum brake are exactly the same as the ceffy aprat from the nymber of studs. Oh and the way the rear suspension mounts to the hub. Ceffy has a stud and nut where as the r33 has a bolt which screws in. Basically u have to do a bit of fiddle with the rear drum to swap the ceffy handbrake cable over as the r33 is too long. But it all fits fine and dandy!. I also put new brake lines on the rear as the r33 a tad too short and the ceffy ones also dont fit because of the banjo bolt which puts them at a funny angle.
BMC i upgraded to a bm 44 with 3 outlets on the same side so it was a straight swap to. (found this on an r30 at pic and payless of all places ....dont think it was original on the r30. Only cost me 25 bucks and it worked hahaha.
have been driving around a few weeks now and all is good quite a simple upgrade in reality considerign how many things could be different but arent. One of friends with a 68 mustang was bloody jelous of how easy it was to do ....and really no major customisation of anything.
ok now getting to the s14 LCA's these push the hubs another 10mm roughly further out. Now i know u can use the ceffy items which is what i would like to do because i cant put wide wheels on my car very well anymore with out rolling and flaring. ie my previous works s1s would now sit 15 mm from the guards not 5 like they use to. So why dont the hubs fit to the ceffy LCA's ? is the diameter of the bolts on the ball joint? too small? cheers
Edited by Resin
s14/r33 front uprights will mount on a31/s13 LCA's with r33 balljoints pressed in ($80 bucks at pedders for 2x brand new r33 balljoints... s14/r33 are the same)
then the r33 brakes go straight on - on the front
customer brake lines are required as cef is banjo where as r33 is a screw type brake line (i used r32 lines with an adaptor... as a temp fix... its too long but it works)
rear - r32/r33 rear hubs slot into your uprights so you can retain your drum handbrake setup...
rear calipers and rotors slot straight over... once again same dealio with the brake lines
i cut the brake dust covers off also front and rear...
cool thanks for the info regarding the r33/s14 ball joint stuff ...will do this soon although i just got a wheel alignment but ohwell. I find it tracks the road more than it used to ...better after wheel alignment but still more than it use to.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
