I dumped the codes from my ecu and got 21-ignition circuit, and 11-crankshaft postion sensor. My #6 cylinder does not seem to be firing at all, the voltage coming from the ignitor on the #6 lead is only 0.73v @ idle. I've tried different coils, plugs, ignitors, and crank sensors, even the coil harness as well and the problem persists. My question I guess would be is, would my ecu be f**ked? Would adding something like an E-manage help correct the problem, or should I try to get another ecu. As a side note, I recently converted my RB20DE to an RB20DE+t if that would have any effect on the problem. I did by the way upgrade the injectors to stock turbo ones, and the stock ecu from DE to DET. My fuel press. at the rail is approx. 38psi @idle and approx. 45psi under load. My turbo seems to be able to hit 12+ psi with no problems, although anything over 7psi and the engine starts to burp and fart. :rant:
https://www.sau.com.au/forums/topic/168042-ecu-error-codes/
The DE is a much higher compression engine than the DET - you DO NOT want mega boost running through the engine, 7psi should be heaps. Over 7 it is probably preparing for detonation heaven.
To the coils - have you swapped the #6 coil with one of the others, eg#5.? What happened?
https://www.sau.com.au/forums/topic/168042-ecu-error-codes/#findComment-3109005
Found the problem after swapping every component out and having no luck, the injector was stuck and flooding the shit out of the cylinder coupled with the fact that the #6 lead on the injector harness was hatched as well. I swapped out the injector and harness for #4,5,6 injectors and no more problem. I also turned off the correct on my afc-neo and it cleared up even more. As for the knock sensor and crank sensor, all I did was add an extra ground to the crank sensor and that problem disappeared as well. :)
https://www.sau.com.au/forums/topic/168042-ecu-error-codes/#findComment-3114018
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
