I dumped the codes from my ecu and got 21-ignition circuit, and 11-crankshaft postion sensor. My #6 cylinder does not seem to be firing at all, the voltage coming from the ignitor on the #6 lead is only 0.73v @ idle. I've tried different coils, plugs, ignitors, and crank sensors, even the coil harness as well and the problem persists. My question I guess would be is, would my ecu be f**ked? Would adding something like an E-manage help correct the problem, or should I try to get another ecu. As a side note, I recently converted my RB20DE to an RB20DE+t if that would have any effect on the problem. I did by the way upgrade the injectors to stock turbo ones, and the stock ecu from DE to DET. My fuel press. at the rail is approx. 38psi @idle and approx. 45psi under load. My turbo seems to be able to hit 12+ psi with no problems, although anything over 7psi and the engine starts to burp and fart. :rant:
https://www.sau.com.au/forums/topic/168042-ecu-error-codes/
The DE is a much higher compression engine than the DET - you DO NOT want mega boost running through the engine, 7psi should be heaps. Over 7 it is probably preparing for detonation heaven.
To the coils - have you swapped the #6 coil with one of the others, eg#5.? What happened?
https://www.sau.com.au/forums/topic/168042-ecu-error-codes/#findComment-3109005
Found the problem after swapping every component out and having no luck, the injector was stuck and flooding the shit out of the cylinder coupled with the fact that the #6 lead on the injector harness was hatched as well. I swapped out the injector and harness for #4,5,6 injectors and no more problem. I also turned off the correct on my afc-neo and it cleared up even more. As for the knock sensor and crank sensor, all I did was add an extra ground to the crank sensor and that problem disappeared as well. :)
https://www.sau.com.au/forums/topic/168042-ecu-error-codes/#findComment-3114018
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
