be using the 180 for drift. and its going to be a 180 rolling shell so yeah
The RB20 would be perfect if you wanted to push your centre of gravity forward, encounter packaging issues fitting bigger heat exchangers, as well as increasing the car's total weight, while having less midrange torque.
https://www.sau.com.au/forums/topic/168043-rb20-in-180sx/#findComment-3110021
If you can afford an RB25DET I'd suggest it.
You can set the car's suspension up, to a certain extent, around the extra nose heaviness from the bigger engine and if its drift-only then making major changes to the front end to fit all your coolers isn't an issue.
The SR20 will make more midrange torque than an RB20 (while probably having just as much top-end) but there's no replacement for displacement.
https://www.sau.com.au/forums/topic/168043-rb20-in-180sx/#findComment-3110083
Umm... If you have an R32... Wouldnt it be more logical to put an RB25 in to that, and sell the RB20 to someone who wants to waste their time putting it in to something it shouldnt be in. ie a 180.
Just a thought.
https://www.sau.com.au/forums/topic/168043-rb20-in-180sx/#findComment-3112913
RB25's are god, RB20's are shit.
sorry, dont mind me, im just trying to fit in here on SAU.
hehehe thats so true (the 2nd part)
I know a bloke with a stock rb20 in a s14 (had a CA previously) and it's alot quicker than another friends standard sr20 powered 180... but then the cars lighter i guess
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/168043-rb20-in-180sx/#findComment-3120565
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
